08-29-2011, 06:03 PM
Moderator
Originally Posted by dezolen
Only way to improve mileage to any extent is take shorter trips or don't drive it at all.
Yep, or change your driving style and speeds. It will have much more effect.
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
08-29-2011, 08:25 PM
superchips ...
I have had a Superchips tune in my Nissan Frontier for over two years. I run it only on 87 octane tune, Thottle restriction off, speed limiter off, rev limiter on, no advance. The truck clearly runs better, and faster throughout the entire speed range, however the biggest advance for me was the removal of the throttle restriction ..
In no way however does this tuner mess with the shift points of the transmission, as this is controlled by the Body Contol Modual, not the ECM. The cortex only flashes the ECM.
Do i save gas? No.
Why? Because the darn truck is so much fun to drive i like to mash the pedal now and then to the suprise to some very upset F150/Silverado poser truck owners ...
Anywhoo ... claims of gas savings with these devices are at best wishfull. Claims of increased fun and enjoyment are substantial.
cheers D-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
08-29-2011, 08:43 PM
ck out the NEW cortex it does mod the shift
08-29-2011, 08:46 PM
The extra power should help with mpg. Extra power means the transmission doesn't have to downshift as much. Does it? It depends. Having more power usually means you will use more power. Pulling away from an intersection, merging with traffic on the interstate. You will put your right foot down more.I have the Superchips Cortex for my Expedition. If I am cruising with the cruise control on and empty, I notice that the displayed MPG is a little higher. As soon as I pull away from a stop the MPG drops. With the tow tune I have to run premium gas. I am getting about the same MPG but it tows easier.
Bottom line. A tuner/chip might help MPG. If it does you will probably not have it long enough to pay for itself. Mine actually costs me more to tow because I have to run premium gas. I like it because the extra power makes it tows easier and it shifts better (a little firmer) and at the right RPM for the load.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 359 |
| 47 members and 312 guests |
| 64c10, armye7, bayouboys, BigDogD, biggie, cardinal4fun, DAISY BOYKIN, Dunefam, electrician549, elind, essness, fonzie, gljurczyk, greti, grhodes50, Hoo Dad, jaygeo1, jcoff2003, jdefeo1, jmnorr3, JoeyO, kshocklee, ladyff1481, LFugate, Mad4sax, miatared, Namchief, Old car, Pa-cj5, patrapper, Pkdennis0504, railstar, rbrandon, Rest and Relax, Rickstermn, Russ, sail2liv, sandpiper, SinkorSwim, softwarejoe, spike, tentcamper1, transamz9, Trevor43, T_LMurphy, UPGRADER, Vette4trcr |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
