Old 06-25-2018, 09:05 AM   #1
Pex lines and fittings same as house ?
I need to modify some plumbing and wanted to confirm with you guys if the pex tubing and fittings are the same stuff for residential homes that I can get from Home Depot etc
Nomore9-5 is offline   Reply With Quote
Old 06-25-2018, 09:13 AM   #2
cavie's Avatar
Yes it is.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-25-2018, 09:19 AM   #3
ben31's Avatar
If it really is Pex, yes. Many RVs also have braided PVC. You can use many of the same internal connectors and crimping on these as the Pex. Most of the PEX (and braided PVC) I've seen in RVs are 1/2 inch.
Be aware that some connectors like the shark-bite ones, will work on the PEX, but won't work on the braided PVC as their external diameters are quite a bit bigger.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is online now   Reply With Quote
Old 06-25-2018, 10:58 AM   #4
Possibly, there are four popular PEX fitting types which include Crimp, Push-fit , Expansion, and Press.
There are two types of pex tubing, Pex A and Pex B but not sure what the differences are between them.
I recently had a pex crimp fitting fail on my last camping trip. In lieu of camping without being able to turn the water pump on, I ran into the nearest town and bought shark bite fittings and other items to repair the leak. I was planning on the shark bite fix to be temporary but think I'm going to leave it in for good as I think it will outlast my interest in owning this camper.
Skyliner is offline   Reply With Quote
Old 06-25-2018, 01:50 PM   #5
larryandamy
PEX same as house?
Yes it is. The crimp rings are cheap, but the crimper is $65. I bought both at Home Depot, did my 4 crimps and then returned the crimper to Home Depot.
I told them what i did and they had no issue giving me a full refund on the crimper.
larryandamy is offline   Reply With Quote
Old 06-25-2018, 02:01 PM   #6
Or...
Or you could simply rent the crimper from Home Depot. $11 for 4 hours, $16 for a day. It's a little more ethical.
Larry in North Carolina
Larry-NC is offline   Reply With Quote
Old 06-25-2018, 02:30 PM   #7
larryandamy
I did what I did with full disclosure to the Home Depot service desk. They never mentioned that they rent the crimper and said that what I did would be fine as long as it was returned in original packaging and in like new condition. Thanks for the reply about the renting option. But your judgment on my ethics is not appreciated. Your response did not need that sentence. Too much of this kind of stuff is going on in these forums.
Old 06-25-2018, 02:35 PM   #8
Go to Wal-Mart.com.. A crimper can be had for $16 or so. Keep it and extra rings on RV tool bag.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 06-25-2018, 02:35 PM   #9
SailorSam20500's Avatar
FWIW, on my trailer, somehow FR managed to use pex crimp connectors on the braided tubing... I'm wondering how they got the tube into the connector - I couldn't.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-25-2018, 02:59 PM   #10
DouglasReid's Avatar
X2^^ Unethical to use and return just because you dont need it again.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
