Old 03-05-2012, 06:56 PM   #11
armye7's Avatar
For weeks until I get back down there
armye7 is offline   Reply With Quote
Old 03-05-2012, 09:41 PM   #12
armye7's Avatar
Coach power by steps will not come on , anybody no what fix might be???
Old 03-05-2012, 10:16 PM   #13
Try turning on the engine for a few minutes and then hit switch. I seem to remember this issue when battery power too low.
Tbeasley77 is offline   Reply With Quote
Old 03-06-2012, 10:14 AM   #14
armye7's Avatar
Called dealer this morning says there is a reset switch in battery box under steps has anyone seen this
Old 03-06-2012, 11:33 AM   #15
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by Bill m View Post
At the door there should be three switches one is for the steps...mine is the first as you enter, and has a blue light when illuminated.
The co detector is on the ceiling in the bedroom in my unit, at the door is the LP detector a four sided detector, if it bsounds a steady tone it is LP a beeping tone suggests low battery.
The one at the door in mine is a CO and LP detector and the one in the bedroom is a smoke detector.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 03-07-2012, 11:30 AM   #16
CLASS "A" Senior Member
cfsoistman's Avatar
Don, is your detector by the door a CO & LP Detector in one? LP detectors are always mounted low since LP is heavier than air and CO detectors are usually mounted on the wall or ceiling due to CO being lighter than air. Just wondering if there's another model now so when I replace mine I would most likely go with that type of model for additional protection.
You may want to double check that. Usually the Smoke Detectors are close to the kitchen area and the CO Detectors are in the bedroom due to the Generator being close to that area. Our Smoke detector is just above the driver's seat on the ceiling and the CO detector is in the bedroom on the ceiling just outside of the rear bathroom in front of the door.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-07-2012, 01:39 PM   #17
jojo bamboo's Avatar
Exclamation
Originally Posted by armye7 View Post
Picking up be 378 xlf today any suggestions .
Yeah, do a long and slow inspection because after you give them the check they kinda don't know you any more.
Make sure you meet the service manager because theres a very good chance you'll be seeing him again.
Not trying to rain on your parade, just a fact of life.
GOOD LUCK
jojo bamboo is offline   Reply With Quote
Old 03-07-2012, 07:06 PM   #18
Squair box, top left by the relays, there is a leaver that comes out from the center when it is triped,push it back to the center to reset
louis cherry is offline   Reply With Quote
Old 03-07-2012, 07:09 PM   #19
There are two red wires going to this breaker.
Old 03-07-2012, 07:10 PM   #20
You have to lift the steps inside the door to get to this
378xl
