Old 03-08-2012, 09:40 AM   #21
armye7's Avatar
Thanx I will try that
armye7 is offline   Reply With Quote
Old 03-08-2012, 01:18 PM   #22
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
[QUOTE=cfsoistman;167533]Don, is your detector by the door a CO & LP Detector in one? LP detectors are always mounted low since LP is heavier than air and CO detectors are usually mounted on the wall or ceiling due to CO being lighter than air. Just wondering if there's another model now so when I replace mine I would most likely go with that type of model for additional protection.
You may want to double check that. Usually the Smoke Detectors are close to the kitchen area and the CO Detectors are in the bedroom due to the Generator being close to that area. Our Smoke detector is just above the driver's seat on the ceiling and the CO detector is in the bedroom on the ceiling just outside of the rear bathroom in front of the door.[/QUOTE)
The one by the door says CO and LP detector right on it. It has two lights on it, a red one for LP and a green one for CO. The one in the bedroom is a CO detector too, so I was wrong about that. There is a smoke alarm right behind the driver's seat.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 03-09-2012, 04:53 PM   #23
armye7's Avatar
Wow.....just got a call from dealer, says Georgetown has recalled the door to the coach.
Old 03-09-2012, 06:50 PM   #24
Can you post again when you find out what the recall was for on the door.
SinkorSwim is offline   Reply With Quote
Old 03-09-2012, 07:12 PM   #25
armye7's Avatar
Yes, soon has I find out will repost.
378xl
