Old 03-15-2016, 10:05 AM   #21
Thanks to all for your helpful ideas, I have attempted to look at most areas where problems are possible.
My stains have stopped growing, but if indeed they originate from the AC then I would anticipate they will once again grow when we begin using the AC again. So, I want to take a much closer look at the AC seal.
Thanks again
Pat & Gene
ehpeters is offline   Reply With Quote
Old 03-15-2016, 11:24 AM   #22
When viewing my ceiling from an angle, I could see where someone scrubbed the ceiling in many areas...leaving a large spot. I'm assuming they used a harsh cleaner which stripped the paint. I will certainly bring it up when we take it back with many other items on the punch list.
GWTimmons is offline   Reply With Quote
Old 03-15-2016, 11:52 AM   #23
BillMFl's Avatar
Originally Posted by ehpeters View Post
Billmfi - would you mind giving me an idea of where that seal is on the AC unit and how you replaced it
The seal I had replaced seals the rectangular opening where the roof air fits through the roof. I had it replaced by at an RV service near Augusta Maine last summer. Labor and material was about $70. Sometimes the seal can be tighten down without replacing, but I had blown dirt or debris into the seal when pressure washing the roof.
BillMFl is offline   Reply With Quote
Old 03-15-2016, 02:07 PM   #24
Thanks, It sounds like the seal is worth the investment. Then the next issue is getting rid of the pink
Pat & Gene
