Old 06-17-2015, 01:43 PM   #1
Pink Ceiling Stains
Hello All,
I have a 2012 Georgetown XL 378 which has developed some pink stains on the ceiling between the front A/C and the drivers side slide, it has also expanded toward the front to the next ceiling partition. It does not clean with either water or a mixture of dish soap and water. I and a RV repairman have checked the roof and cannot see any likely spots where a leak might be, but we did not pull the A/C unit up to make sure it was installed correctly.
Anybody have any thoughts on these pink stains?
Pat & Gene
ehpeters is offline   Reply With Quote
Old 06-25-2015, 08:54 AM   #2
I am having the same problem with my 337XL. I cannot find a leak anywhere and have not checked the Air Conditioner either. Any suggestions are welcome.
2012 Gerogetown 337XL
Tow Dolly
DW of 24 Years.
Hope to meet you on the trail.
ejw7213 is offline   Reply With Quote
Old 06-25-2015, 04:11 PM   #3
It's nice to know that at least somebody else has the same problem. Have you talked to Forest River, I spoke with Kevin Stratton and he thinks it is a leak and suggested taking it to a dealer but the one he recommended is about 90 miles away and the RV tech didn't see any signs of a leak so I don't know what to think. The stains do not seem to be growing but no rain here yet.
Pat & Gene
Old 06-25-2015, 04:26 PM   #4
Crockett's Avatar
left over champagne from the office party last christmas?? hehe, i woundnt joke around if I didnt have a remedy. this stuff worked on every ceiling fabric stain ive used it on.havent tried in on anything other than a cloth type fabric...not sure the material on the georgetown...usually takes 2 applications
Crockett is offline   Reply With Quote
Old 06-25-2015, 04:32 PM   #5
Probably the drain from the ac is not draining completely to the outside. The ac cover will have to come off and inspection done on the drain. Would not try to remove the stain or cover it up until the cause is found.
Old 06-25-2015, 10:35 PM   #6
Thanks for the suggestions guys - I have taken the cover off and looked at the drain, however it wont hurt to double check.
Pat & Gene
Old 06-25-2015, 10:54 PM   #7
jergeod's Avatar
How about condensation from the A/C runs in the ceiling, I have a hard ceiling and if very humid with a/c running I get drips around the a/c ducts outlets and I would imagine the ducts themselves will sweat also. I get yellow marks.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 06-26-2015, 12:09 AM   #8
Just a member
kandl's Avatar
Your pink stains, if it is what I think it is, are typically associated with the presence of vinyl coated/impregnated products. I and many others have had to contend with this nuisance stain on our awnings. It is not mildew. It's a by-product (poop) of bacterial micro organisms. The by-product manifests as a dye that is soluble in the plasticizers commonly found in vinyl coated products. The marine (boating) crowd are more familiar with this. We've had some success at removal with a diluted mix of household bleach but again, if that's what is staining your ceiling/s, where's the vinyl component?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-26-2015, 12:23 PM   #9
Pink Ceiling Stains Pics
I have attempted to add some pics of the ceiling stains, but not sure how they will turn out
ID:	81182   Click image for larger version
ID:	81183   Click image for larger version
Pat & Gene
Old 06-26-2015, 12:27 PM   #10
TURBS's Avatar
Wet " pink" insulation stain?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
