10-02-2014, 09:35 PM
Pole Barn for 378
Has anyone built a pole barn to store your MH? I am considering one and will have it heated for the winter. Any words of advice and what kind of cost am I looking at? Will also have a 50 amp.
10-02-2014, 09:41 PM
Only advice I can offer is to plan on building it with a 14 foot high overhead door and half again longer than what you think you might need.
Never know when an upgrade will need the space.......
10-02-2014, 09:50 PM
For heat, use hot water in-floor heating. The floor will be toasty warm to walk/lay on to work on your vehicles and you won't be heating the air space - wasting money.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
10-03-2014, 06:55 AM
Never to big or tall......mine is 204'x 36' and RV wont fit.
10-03-2014, 07:16 AM
Holy cow - that is one long barn. Not sure if it s just the way the photo was taken, but looks like you could fit a whole campground inside that thing.
I have to assume your RV won't fit b/c of height, right?????????????
PurduePete
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
10-03-2014, 08:08 AM
I have 2 pole barn buildings. One is 32'x64' and the second is 45'x18'. The larger building was on the property when I bought the acreage in 1987 and I built the second one about 15 years ago. If I remember correctly, this building was about $10-$11K with 30 amp service (which I totally installed/wired)and a gravel/lime based floor. I'm guessing it would cost more than twice that amount, even approaching $30k with a cement/heated floor today. Good luck, I certainly wouldn't be without my buildings!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
10-03-2014, 09:03 AM
Happily Retired Member
Pole Barn
I had a 30X40 pole barn with a 14 ft ceiling prior to the 2013 378 MH. It fits but not a lot of room. So off the back wall I used a 2x4 with a 6x6 block on the end for a rear wheel stop leaving just enough room to get behind the MH to plug in the power to a 30 amp drop. I found that backing in from the light of day into a darker pole barn that I had so much glare in the mirrors I couldn't see back into the pole barn to back in. I painted a bright red line on the floor that I use as a guide to back in. Works perfect. I do not heat that section of the pole barn.
10-03-2014, 09:14 AM
PurduePete
I only have 12X12 doors and RV is just over 13' tall
10-03-2014, 08:07 PM
I have a 335. Built an unheated, uninsulated garage with a 12' door. Garage is 21x40. Had a class C at the time and had no problems with a 12' door. Bought my GT, which needs 12'1". It actually need 12'3", so I modified my door at a cost of $700. Put the biggest door you can in. 12'6" Minimum. My 35' will barely fit into my 40' garage when your consider 6" studs and other door hardware.
10-03-2014, 09:00 PM
I painted a strip on the back wall that I line the coach up with when I back it in. Even with the glare I can see the strip.
Russell
10-03-2014, 09:09 PM
phat phrog stunt crew
Hard to give a ball park est on cost really. Any grading to be done, trees/rocks cleared? Is site level or always damp? Will you need to get a 911 address to run power to your garage or is the house close enough with enough space in breaker box to support it?
Sent from ny nook using fairly accurate digits.
10-03-2014, 09:44 PM
I've got about $30k in mine. Includes concrete floor, door with opener. I also have a 14x40 foot garage attached to RV bay that I put the rest of my toys in and whatever else my DW wants to store!
