Old 05-12-2013, 08:07 PM   #1
Tim & Lisa Trempert
Poor man's inverter
I am tired of running the generator so my kids can watch TV or charge their Gamebody/Ipod/Etc.
I bought a 750W inverter at Sams for $29.99 and I ran a front circuit to run the DVD player and TV. I will later run a rear circuit to the rear dinette.
First, I had to drill a hole to run the wire from the DVD cabinet (front upper right corner). I drilled it just behind the front shade.
I then ran it through the engine compartment and back along the top of the frame (where other wires run) to the battery compartment under the stairs. I mounted the inverter by 4 sets of tie wraps (redundancy) around a support beam. I currently am just using the alligator clips to connect to the battery, but will make that more permanent at a future date. Now it's off to the hardware store to find a plug to install in the upper cabinet.
ID:	30294   Click image for larger version
ID:	30295   Click image for larger version
ID:	30296   Click image for larger version
ID:	30297   Click image for larger version
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 05-12-2013, 09:24 PM   #2
statgeek's Avatar
Great idea. And with the money you saved, you can buy a ______________!
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
statgeek is offline   Reply With Quote
Old 05-13-2013, 11:31 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
My one concern would be water getting into the Inverter while driving on wet pavement. I haven't seen one mounted in an open area such as yours. Usually they're mounted inside a compartment. Water & Electricity don't go together well.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-13-2013, 11:41 AM   #4
K9-24's Avatar
X2 on the water!
K9-24 is offline   Reply With Quote
Old 05-13-2013, 12:18 PM   #5
Tim & Lisa Trempert
At $29 I can afford another one! I'll let you know if I have any problems. It's mounted pretty high.
Tim & Lisa
2011 Georgetown 350
Old 05-13-2013, 04:27 PM   #6
abjb's Avatar
Put it in a ziplock bag or 2.
If water gets in it you'll know real quick !
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 05-13-2013, 08:02 PM   #7
mshell56118's Avatar
Also be careful with that style inverter it is a modified sine wave using that to charge batterie will greatly hurt the capacity of the battery and can also cause problems with electronics.
mshell56118 is offline   Reply With Quote
Old 05-13-2013, 08:07 PM   #8
Tim & Lisa Trempert
I'll let you know if I have any problems. I've used a similar one in my car for years with no issues.
Tim & Lisa
2011 Georgetown 350
Old 05-14-2013, 09:49 AM   #9
ronhanson's Avatar
I did something similar except mounted the inverter under the passenger seat. I used a modified sine wave inverter for a couple years but switched to a pure sine wave to eliminate some odd interference patterns on the tv. The ipad/iphone chargers didn't like modified sine wave unit I had either.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 06-13-2013, 10:04 PM   #10
I too would like to add an inverter on my 2013 xl 378. I am looking at putting it behind the 12 volt fuse panel and then taking the wire off of the 15 amp breaker and running it into a DPDT switch so I can switch it back to 120 when parked at a site. The DVD/radio should still play the movie and the TV over the fireplace will be powered by the inverter.
Does this sound possible to anyone?
wrapperman is offline   Reply With Quote
