Old 08-08-2014, 11:48 AM   #21
Iggy's Avatar
Originally Posted by abjb View Post
Time for the BIG question.
Is anyone satisfied with their omnidirectional antenna?
ab&jb
No and that is why I now have a Jack which I installed.
Old 08-08-2014, 12:56 PM   #22
cjd10's Avatar
ab&jb
Nope. That is why I have been following this thread to see what my best option is
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 08-09-2014, 01:22 PM   #23
43D18's Avatar
Seeing how I started this thread, my answer would be "no" as well. Back home in our drive in metro Nashville, I'm getting about 10 channels. Far more than any other place we camped in the past week. I'm guessing that's because we are quite close to various stations in the metro area, but even here, we aren't picking up two of the "big three" network channels.
For those who have installed the jack, any tips on installation for those of us who don't know "jack" about antennas? Does the Jack require a hole in your ceiling or does it simply replace the omni directional antenna that's up there already?
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 08-09-2014, 01:36 PM   #24
Iwannacamp's Avatar
Hmm. Prolly goes without saying, but geography plays a big role in the performance of the antenna. I camped a few miles away(on the same lake) and one location I got nearly nothing...one location got several channels(three sites in the same CG) and got different results. All weak it this CG... I was avoiding the DirectTV deal... May have to go for it or pick an off-air option that works. Hmmm
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 08-09-2014, 02:09 PM   #25
43D18's Avatar
So I just looked at the antenna and I have a question for those who have this round, "flying saucer" omni-directional antenna: it is supposed to be loose...so much that it spins freely and wobbles a bit on the metal post that enters the coach? The metal post is firm, but the plastic "flying saucer" portion of the antenna is exceedingly loose. I'm not even sure how it's secured to the mounting post, or how you would tighten (if you even can). After spinning it a couple times to see if it would thread itself tighter (it didn't) I saw a couple small metal shavings come out. That's always nice to see.
Still wondering if it's even hooked up, and how I can tell if it is or not.
Hmmmm
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 08-09-2014, 08:11 PM   #26
abjb's Avatar
More info
A friend has an omnidirectional antenna that doesn't work at his house, our King picks up several (30+) hand held on his roof using the coax that goes to his antenna.
Installing a Jack will require a hole in the ceiling, the hole in the roof of my friends SOB looked like the manufacture was still using the same size hole they used for the bat wing.
Hmmmm
My friends was nice and tight, he didn't replace or use it.
He uses a RCA Digital Flat Indoor Antenna.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 08-09-2014, 08:59 PM   #27
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
ab&jb
Nope; I trashed mine too and installed a Jack. Big difference and I'm quite satisfied. I let Camping World install it for $39 and let them deal with it. I received 22 stations at the FROG rally in Goshen.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-12-2014, 01:51 AM   #28
We have the same issue and all 5 of our tv ' s get different channels and some tv ' s get nothing. It's really odd. I scan for channels at every park on can't cable or air. Just can't figure this out.
sdowning is offline   Reply With Quote
Old 10-12-2014, 10:26 AM   #29
43D18's Avatar
Since I started this thread I should update it - now that our antenna is connected properly, I'm quite satisfied with it. The bummer is that we've had the coach an entire year thinking it was just a crappy antenna and therefore didn't pick up many (sometimes any) channels. Finally upon my urging, the dealer agreed to remove the antenna and see if the connections were intact, and bingo - they were not. The secured the connections (at the antenna) and now I can tune in 30 stations in my driveway where as previously I would get a couple.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 10-13-2014, 08:25 AM   #30
Fireman
Send a message via AIM to dutch
TV Reception
43D18 we have the same problem with our reception, after camping this last week I was on the roof and checked the round att and it was loose too did you ever find out how remove it/ tightened up/ or how to check the wires to see if it was hooked up. or has anyone else done this. My one year warranty is up now so I want to see if I can do it myself. Plus my dealer takes a long time doing anything on the coach.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
reception, tv reception
