Old 07-28-2014, 01:50 PM   #1
43D18's Avatar
Poor / no TV reception
So, we've never really been able to tune in many channels over the antenna, and in some cases, none at all. I'm wondering if the antenna is even hooked up. I've heard various comments on folks loathing the antennas they put on the new GT's, but surely we should be able to get a few channels.
We are usually in a park w/ cable, but the occasional times, like now, that we're not, we can't seem to get even local channels. Right now we are in Niagra Falls. Recently when camped 30 mi from Memphis, couldn't get a single channel.
The selector box in cabinet above passenger is set to "antenna", and the antenna booster switch in back of cab is "on" with the green light illuminated. TV set to tune channels over the air / antenna. Connections going into selector box are all tight. No issues when tuning channels when hooked up to cable.
Ideas?
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 07-28-2014, 02:09 PM   #2
kenandterry's Avatar
Looks like you've got everything covered. You're right.........it should work.
I would test the continuity of the coax starting at the connector of the antennae on the roof. I made my own kind of audible testing equipment to do some work on our rig a few years ago. I would bet there's an open connection somewhere between the actual antennae and the selector box coax end. When you move the selector to cable, you're saying your televisions work just fine.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-28-2014, 09:46 PM   #3
Is there anything in the set-up menu on the TV that needs to be changed from "cable" to "over the air?"
Clemdog is offline   Reply With Quote
Old 07-28-2014, 11:27 PM   #4
iluvlcy's Avatar
Have you had the tv do a channel search to find channels in the area you are in?
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 07-28-2014, 11:38 PM   #5
RSchleder's Avatar
EXCELLENT thought!
RSchleder is offline   Reply With Quote
Old 07-29-2014, 07:45 AM   #6
Originally Posted by RSchleder View Post
EXCELLENT thought!
X3. Everytime you move you've got to rescan for local channels.
Old 07-29-2014, 10:59 PM   #7
I have experienced the same problem. Had no channels after a scan and all inputs correct. My neighbor was receiving 7 channels right next to me with the crank up older model. We ran a coax cable from his antenna to the back of my selector box and guess what. Yep, 7 channels! We trouble shot all the things we could think of and came to the conclusion it must be a bad antenna. Looking for a replacement now.
pkhill is offline   Reply With Quote
Old 08-03-2014, 11:51 PM   #8
43D18's Avatar
Yes, as indicated in my post, tv is set to tune over air
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 08-03-2014, 11:52 PM   #9
43D18's Avatar
Um, yes...that's the issue. It's not tuning any channels.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Old 08-03-2014, 11:53 PM   #10
43D18's Avatar
Yes, of course. Figured that was a given.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
reception, tv reception
