Old 08-12-2018, 01:12 PM   #1
Poor quality control and cheap materials used in my 2016 Georgetown.
I have a 2016 Georgetown and are having way too many Quality Controll issues. My steps pop out while driving for no reason. My wood trim around the slide out is cracking. The sliding door in the back to the bedroom track has broken and the rails have come loose as well making that door not functional at all. For the amount I paid for this RV I am Appalled at the lack of quality of materials used and broken and defective equipment!!! I called the dealer where I purchased it from and was told there was only a 1 year warranty and will not be covered I was floored!!! What can you do to fix these issues? THIS IS COMPLETELY INEXCUSABLE!!!
Respectfully,
Mr. Steve Schneider
Schneikeys is offline   Reply With Quote
Old 08-12-2018, 02:36 PM   #2
Iggy's Avatar
Steven sorry to hear about your issues but we all have been there.
The only difference is that we had our issues resolved with in the 1 year period.
Many other here will tell you a lot worst stories but that doesn't change anything.
ALL trailers and motorhome manufacturers have the same mindset.
Get them out of the factory as quickly as possible and to the dealers and let them handle the minor repairs.
Like I said all manufacturers use the same mindset.
So the answer now is can you handle the repairs yourself or have to hire someone.
We can assist if you have any problems figuring out what is the best method of repair.
Like I said many have had the same issues as you in the past.
We are here for you.
2012 Georgetown XL - 378TS 63K + miles
Old 08-12-2018, 05:15 PM   #3
Driving a motorhome across the USA has been compared to a 7.0 earthquake, so it's no wonder that things fall apart. The wonder of it all is that most RV's are not a pile of junk alongside every interstate.
We all have problems, so we all either get them fixed, or we become carpenters, electricians, plumbers and chassis mechanics to keep our RV's on the road. I have just spent time repairing my step, replacing hydraulic hoses, replacing light bulbs, cleaning my water lines and repairing the bedroom sliding door.
If you can send some pictures of your problems, someone on here has fixed your issue and I'm sure would be willing to help. Happy camping
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days
mogman is offline   Reply With Quote
Old 08-12-2018, 05:17 PM   #4
Thank you I will take some pictures and post them...
Old 08-13-2018, 01:22 PM   #5
I've fixed the sliding doors on my burkshire bunk house a few times not a hard job
Think the problem is the screws are way to short and the wood at the top of the doors is to thin
What you need to do is take all the doors off and out of The unit cut a strip of 1/2 plywood the size of the top of the door glue and screw the wood to the top of door
And when you put the hardware back on use longer screws also if the door has any back and forth play in it put a few wood block on the back edge (nice quiet ride).
Did this 2 years ago no more problems if you have a tablesaw job will. Be easeyer
Don't use pine it will crack you will be back ware you stared good luck
Blazer is offline   Reply With Quote
Old 08-13-2018, 02:02 PM   #6
Following this . . .
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 08-13-2018, 03:01 PM   #7
Re: steps coming out while driving. Had same surprising issue with Georgetown XL when new. Our problem was in the screen door not making contact with the sensor (?) on the frame of the door 1) screen door maybe slightly out of square/twisted may be better term. Check that. That solved our issue but now we lock the door so a pothole doesnít t jar causing a disconnect of screen with frame. No more issue. Yep as others said we need to become resourceful and In Some cases DIY. This forum can help- some smart/experienced people here
I feel your frustration with dealers and unexpected issues Good Luck
twoclaws is offline   Reply With Quote
Old 08-14-2018, 07:40 AM   #8
360true's Avatar
Re the stairs popping out whilst driving. The door magnet vibrates over the road. For a while, I taped a magnet on the door frame. That worked, but was a pain to do. Recently installed a switch inside to the stair power. Now when it is "off", no power possible to the stair motor. Jumped the red wire to the new switch.Click image for larger version
ID:	183225Click image for larger version
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 08-14-2018, 09:41 AM   #9
Vince and Charlette's Avatar
The Best RV maintenance quote I've heard: "Your RV has to be your hobby." After three years, I traded in a 2015 GT 364 BH for a Berkshire...BIG difference in quality. But, I found both have their issues. If you have some reasonable DYI skills, then I suggest you keep a list and tackle them one at a time. Hardly anything can't be found on this site. If it can get broken, someone has already shown how they fixed it. YouTube is also a good source of videos on repairs. However, if it is a major item, or over your DYI skills, I suggest you go to an independent RV garage where they are motivated to get the job done right and out the door. Avoid dealers, especially Camping World, if at all possible. (This site is littered with CW nightmares.) Anyway, post your request for assistance, and you'll probably get a response or two before the end of the same day. Happy camping!
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 08-14-2018, 10:38 AM   #10
GOOD SOUND ADVICE from you and 360True
georgetown, quality
