Old 07-25-2013, 09:33 PM   #1
Pete
gartonhl's Avatar
"Popping/creaking" noise
2010 Georgetown 378TS; 26k miles. We are fulltimers.
We’re currently camping in Ouray, CO. on a perfectly level concrete pad.
The level “bubbles” are perfectly centered. Both rear doors stay in place; do not open or close on their own accord.
When we walk through the MH, or other movement within the coach, there is a “popping/creaking” noise that comes from beneath in the chassis area. I got underneath today to check and did not see anything loose from the “jacks” perspective or the sway bars.
We’ve been here for 4 days and it started. This has happened many times before and it seems to start anywhere from 3-5 days after being on site.
Has anyone had the same occurrence? Or, have any ideas?
Thanks in advance.
Pete
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 07-25-2013, 09:55 PM   #2
Newellri's Avatar
Thanks in advance.
Pete
Yup mine. Also after about ten days.
Newellri is offline   Reply With Quote
Old 07-25-2013, 09:57 PM   #3
Newellri's Avatar
Yes mine does this after about ten days. It comes from the jacks, I have held one in my hand when it happens, you can feel it. No idea what causes it.
Old 07-26-2013, 07:36 AM   #4
Us also. Don't have a clue what causes it but seems to come from the jacks. The rig stays level though.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 07-26-2013, 11:41 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
I'm just wondering if temperature has anything to do with it. Have you ever been near a house with vinyl siding when the sun first comes up and starts to shine on the wall. The siding creeks and moves as it heats up. Might be the same thing?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-26-2013, 07:47 PM   #6
Newellri's Avatar
I have had a hand on one when it popped it .... No idea what it is but you can feel it.
Old 07-27-2013, 09:08 AM   #7
Iggy's Avatar
My guess it is the expansion of fluid in the system or you have a slow leak back to the tank and the system is re-pressuerizing
2012 Georgetown XL - 378TS
Old 07-27-2013, 10:50 AM   #8
Newellri's Avatar
It happens as you move around the MH.
Old 07-27-2013, 11:34 AM   #9
Pete
gartonhl's Avatar
New Hydraulic lines/pump. No "drips" from either source on ground/concrete pads. No "oily/dirt" on any jack piston or brackets, fittings into pump, motor or hydraulic fluid reservoir.
It happens when there is movement in the coach.
What do you mean by "slow leak back to the tank"? What do you think the cause of your "guess" would be; and resolution of same? How would I detect it?
Pete and Patty
Old 08-09-2013, 07:14 PM   #10
intercept's Avatar
You may have a pressure relief valve reducing the line pressure. Lets say the system is under 1500 psi during your stay while it is holding the coach up and that was done at 60 degrees F. If the temp goes to 85 the hydraulics may increase the fluid pressure past a safe level and release some fluid back into the reservoir. As you walk around you may be adding the twig that sets the pressure past the safe point and a pop. Try lifting the jacks just a notch and see if that takes care of the issue. If it does you at least know it is the jacks.
Let us know
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
