Old 10-06-2014, 03:07 PM   #1
Power converter
have a 2015 FR Georgetown 35. While plugged into shore power my batteries are going dead. I pulled the cover off the silver box in the rear which is the converter and the small green light at the base is not lit. Any help on where to start to resolve this issue is greatly appreciated. Maybe where the fuse is??? I have a trip in a week. I have called warranty number and it is seems to be kind of hard to get in touch with someone, but maybe they will call today.
bstovall is offline   Reply With Quote
Old 10-06-2014, 05:01 PM   #2
Happily Retired Member
Not sue about the green light but make sure your battery switch is on.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 10-06-2014, 05:10 PM   #3
cjd10's Avatar
Yep, what he said. However, don't assume your battery switch is on just because it is lit. The light in my switch stays on in the off and on position
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 10-06-2014, 05:12 PM   #4
Battery disconnect is on.
Old 10-06-2014, 05:18 PM   #5
fonzie's Avatar
make sure your converter ac breaker is on in the distribution panel (if located there)
Fonzie
Old 10-06-2014, 06:39 PM   #6
cjd10's Avatar
Don't know if this will help or not. I have not physically looked at these fuses. This is just a note I copied from a post for future reference if I needed it;
Fuse one - protects the battery and is located right AT the battery. If this is open everything works in the camper (including slides and stabilizers) when on external power, there is 13+ volts on the camper, and yet the battery will not charge.
Fuse two - protects the camper from the tow vehicle's charging circuit and is located near the pigtail junction box. If this is open (and you are on shore power), everything works inside at 13+ volts BUT the main slides, power stabilizers/jacks, and power tongue jack (if equipped) will not and the battery will not charge.
Charleston SC
Old 10-07-2014, 07:38 AM   #7
Converter
Make sure the converter is plugged in. On my 378, the converter is in the last bay, left side, where the ATS and power cord are. One must put his upper torso into the bay to see where the converter plugs in to a 110V outlet.
goodstick is offline   Reply With Quote
converter, power
