Does anyone know which fuse controls the power shade, radio, map lights, & cig lighter? 2012 378XL. Fuse blew last night, got fuses at FJ but book does not say which one it is. They are a real bear to get to as well.
2021 Forester 3051
2017 Ford Focus Toad
Go to any auto parts store and pick up a 12v test light. Hook up the clip to ground and touch each fuse on both sides. The one that doesn't light up on one side has popped. Note that some fuses will not be powered up unless the ignition is on or in ACC.
The power shade has a hidden reset button. On our coach it's tucked behind the trim on the upper left side of the windshield area.
See picture foe location of #16 which is a yellow 20 amp fuse.
"If not there then look under and to the left of the steering wheel, under the dash."
Believe this is correct however the number could change with model
or year. Use the circuit tester to ID the proper number. To access move seat all the way back, approach on your back and roll into position, not easy.
It's most likely going to be the fuse panel under the dash on the left hand side. The stuff you mentioned is on the car side of things, not the house side. If you are in a hurry to get it fixed, pull one fuse at a time to see which one is busted.
Just a thought, but on the travel trailer we used to have, whenever a fuse was blown you could tell by an LED next to the blown fuse. On our coach, the fuse panel is on the side of the master bed and it's pretty simple. You'd have to either have a test light or pull one fuse at a time.
I seem to have a bad cig lighter. Will have it looked at next week when we get home when they put in the new frig. Getting it ready for Xmas trip to NOVA to see kids.
2021 Forester 3051
