Old 03-13-2011, 04:53 PM   #31
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by starburst2 View Post
Thanks for the info Charlie. And to you too Don. I suspect you already have your shades installed. Do they hang free and thus swing when you accelerate and deccelerate or do they travel in a channel that is mounted on the posts alongside the windshield as do those I've seen in the actory installations? For 1/5 th factory price I suspect they just ang free but just had to ask.
Thanks for the feedback.
Regards,
Lloyd
No, they don't swing free. They have a metal frame that faces toward the window and expands as the shade goes down, much like one of those baby fences people put in doorways in the house. They do not travel in the groves that are in the post covers.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 03-13-2011, 08:10 PM   #32
You mean one of those pantographs
starburst2 is offline   Reply With Quote
Old 03-13-2011, 08:55 PM   #33
I Have a 2011 378ts georgetown ,but it is in storage and i am away from home my question is the a-piller should it have the grove for the sun shade
marclaw15 is offline   Reply With Quote
Old 03-14-2011, 10:16 AM   #34
nemo45's Avatar
Yes, simular to that. You won't see it from the inside of the coach, though, if you install them properly. All the shades Shadepro has are for the left hand side, so the wires will be coming out of the left side on both of them. To hide the wires coming from the shade on the right you're probably going to have to route them thru the overhead cabinettes.
Old 03-25-2011, 07:48 AM   #35
Ended up having the single night shade installed due to a mix up at the dealers. Will now look for a sunscreen to mount either on the inside or outside of front window.
2010 373DS
Master Tow with 2008 Nissan Altima
bresdogsr is offline   Reply With Quote
Old 04-14-2011, 10:16 PM   #36
Thank you Nemo. These sound very much like they would warrant further consideration. As others have so adeptly stated; the existing factory sunvisors are virtually useless as you cannot adjust them while driving. In fact , you cannot even reach them. Poor engineering or ill thought cost cutting?
Lloyd
Old 04-18-2011, 11:12 PM   #37
Los Popes's Avatar
After reading this thread when it started I decided to buy a set of the 43-inch wide visors from Shadepro on eBay a few weeks ago and was able to find the time to install this past weekend. Boy what a difference they make and for $73 each it was a steal. I searched around and most sites wanted $200 or more a piece for one visor.
I can't believe I went a year and half with the skimpy factory visors. The install was a breeze - yes they are both left-hand motors so I had to splice wires on one of the units in order to reach the remote control unit - but it was very easy. Wireless remote mounts anywhere you want on the dash and you are good to go.
If you don't have power visors, I strongly recommend getting a set of these before Shadepro runs out of inventory.
Bubba & Chiquita + Two Vizslas (Barley and Sophie)
2008 Georgetown 315DS SE LTD
2011 Jeep Wrangler Unlimited Rubicon
Sterling All-Terrain Tow Bar - SMI Stay-In-Play Duo
Do What You Like - Like What You Do!
Los Popes is offline   Reply With Quote
Old 04-19-2011, 07:53 AM   #38
nemo45's Avatar
Ditto!
Old 04-19-2011, 09:59 AM   #39
Robby1139's Avatar
I also took the great advice on this forum and installed these automatic visors (agree with a previous post regarding having to bend yourself into a pretzel a few times under the dash tho!). They work great and I was able to do a clean install without any exposed wires. I also installed the new Clarion NX501 in dash GPS multimedia head unit along with some upgraded Alpine speakers. Ready to head out this weekend on maiden voyage of 2011! Cheers,
Hugh
Robby1139 is offline   Reply With Quote
Old 04-28-2011, 11:36 AM   #40
Does anyone have pictures of the factory mounted shades done aftermarket? I was talking with the factory rep and he said I would have to replace the entire bulkhead to mount the shades. I guess from they factory they are recessed? It sounds like maybe some of you mounted them flush on the bulkhead and they work fine.... is that correct?
Thanks, Randy
2010 Georgetown 300 FWS
2003 Jeep Liberty
blue283 is offline   Reply With Quote
