Old 06-05-2015, 11:38 AM   #1
Mature Citizen
downeyr's Avatar
Power to Slides
I have lost all power to my slides. I have a 2013 XL 378TS. The jacks work and there is power through the circuit breakers. I have checked all the fuses I can see and none of them will work. Any other ideas? Thanks.
Darlene, Ralph and Pippin
LTC (USA Retired), W7TLD
2017 - 188 days & 7944 miles
2013 - 2016 - 432 days & 21429 miles
2013 Georgetown XL 378TS, 2014 Honda CRV
downeyr is offline   Reply With Quote
Old 06-05-2015, 11:49 AM   #2
TURBS's Avatar
Follow your positive battery cable from the battery to a manual reset circuit breaker.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-05-2015, 03:19 PM   #3
Iggy's Avatar
Did you check the 100 amp DC breaker?
Here is mine in the upper left hand corner of my battery control center.
If the red arm is sticking out it is tripped.
Push it back in to reset and make sure you are plugged into shore power or generator running.
The reason it would trip is low coach battery voltage.
Old 06-05-2015, 08:29 PM   #4
alsimmon11's Avatar
Check and make sure you have fluid in the reservoir under the steps.
alsimmon11 is offline   Reply With Quote
Old 06-08-2015, 08:43 PM   #5
McCamping Clan's Avatar
I had the same exact issue last year with my 2013 352QS. There is a fuse in the Battery Control Center box (box pictured in IGGYs reply above). The fuse was either a 10a or 15a. If I remember correctly, it was towards the bottom right of the box. This drove me, and electrician and a RV Tech crazy for several days before we located it. Hope this helps.
McCamping Clan is offline   Reply With Quote
Old 06-09-2015, 05:56 AM   #6
Tim & Lisa Trempert
If your jacks work it's the same motor and fluid system so I doubt it's a breaker or fuse. The slides have a lockout when the engine is running. Try turning the engine on and off and wiggle the key a little and remove it and then try again. If it still doesn't work I'd track down the lockout circuit that disables the slides when the engine is running.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-12-2015, 12:52 AM   #7
2:00 am, you guy saved me
Thanks for this thread
cbmerton is offline   Reply With Quote
Old 08-12-2015, 06:27 AM   #8
TURBS's Avatar
What was it that fixed yours?
TURBS
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-12-2015, 07:05 AM   #9
I agree, what fixed the issue. I'm eager to learn.
It's like watching a good football game that's tied with 10 sec to go and the power goes out 😩.
Glad you got up & running. 😎
MrGrmpy is offline   Reply With Quote
Old 08-12-2015, 07:27 AM   #10
Reset the circuit breaker but,also the 15 amp fuse in the battery fuse compartment under the stair on bottom right had blown. I think when I auto leveled it blew the breakers and the fuse. The fuse was not marked in that box.
Temporary took fuse from artic pack to get slides to work.
power, slide, slide out
