Old 10-03-2015, 12:40 PM   #1
Problem with backup and side cameras
We have a 2011 Georgetown 373, with side and rear vision cameras. All three cameras work fine, UNTIL I TURN ON THE HEADLIGHTS. When I turn on the headlights, the monitor stays on the RIGHT side camera. When I turn the blinker on to the LEFT side camera, the monitor jumps from one camera to another,sides and back.
The name given on the back of the monitor is MITO, and the camera is called PREMIER VIEW. The SN is MI-1281.
Does anybody on this forum have any experience with this issue, or any suggestions on where to look for the fix to this issue?
Thanks.
akoldtimer is offline   Reply With Quote
Old 10-03-2015, 02:41 PM   #2
Iggy's Avatar
You have a bulb burnt out. May be the turn signal light or even the marker lights will cause what you mentioned. Check them all out tonight.
I you find all lights are working then check the ground wire harness in the engine compartment.
Drivers side pillar near the horn. These wires get loose or corroded where they attach to body. Usually 1 screw holding 3 or 4 wires.
http://mito-oem.com/index.php?route=...product_id=334
