Old 09-16-2016, 02:17 PM   #1
Propane connection on Georgetown 369DS
The quick connect propane connector on the passenger side of coach, Is it connected to the regulator at the tank and do I have to remove the regulator on the grill to use it and use the regulator on the coach.
johnnynsc is offline   Reply With Quote
Old 09-16-2016, 09:35 PM   #2
Iggy's Avatar
Yes it's hooked up to the regulator at the tank and you don't have to remove your regulator on the BBQ for the BBQ to work.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 09-17-2016, 08:25 AM   #3
kentdavido's Avatar
I removed ours because it was explained to me at the service department the pressure would be reduced greatly with two regulators in place.
kentdavido is offline   Reply With Quote
Old 09-17-2016, 09:01 AM   #4
From my experience and understanding, if you leave both regulators in place, you will not have enough gas pressure to effectively grill. I wasn't able to light my old Coleman when connected with 2 regs in line. I couldn't remove the reg on the Coleman, so I used it as an excuse to buy a Weber Q, easily removed the reg and it works great.
Darugs is offline   Reply With Quote
Old 09-17-2016, 09:21 AM   #5
mikkeeh's Avatar
You cant run the gas through two regulators. The best option for me was to purchase a grill designed to run on a regulated LP supply (ie.grill does not have a regulator) I got an Olympian 5500 ....expensive, but money well spent. Really nice quality.
mikkeeh is offline   Reply With Quote
Old 09-17-2016, 10:44 AM   #6
Iggy's Avatar
Not knowing or seeing your exact setup and equipment I can only go by what I have seen and done.
When I had my Rockwood 5th wheel I had a bbq mount and connection on the side of the rig. The bbq had a regulator on it and all I did was attach the hose and valve to the bbq. Worked for me.
The regulator are set to reduce below 20 psi so two in line won't restrict it much. You still should get no more than 20psi.
USAF Retired - MSgt
Old 09-17-2016, 01:17 PM   #7
propane fill problem
We have a 2016 forester 2219s which sat unused for a year before we bought it.On our first trip,at 1/2 full, the small relief valve would not let the tank vent-no hiss.The guy wouldn't fill it,says it's defective.at 1/4 full next guy ignored the no hiss & put 5 gal in which filled it.Why does this valve not bleed,yet allow 5 gal in? Also I was told I had a 33 gal tank,which makes 5 gal seem too low.Can anyone advise me on this small bleed valve problem? Also I don't know where to post this question as this says I'm replying to a post,thanks
huckelbuck is offline   Reply With Quote
Old 09-17-2016, 03:58 PM   #8
mikkeeh's Avatar
Well...it says you are relying to a thread.....because you posted as a reply to a thread. Go the forum you want to post in. Click "new thread". Hope this helps.
Old 09-18-2016, 12:52 PM   #9
SternHappens's Avatar
They told me at the Coleman Store their connections were proprietary and there was no way to jack into the motorhome's propane supply. Well turns out you can put the stock regulator in a vise and bust the connection loose, then a simple 1/4" thread (if I remember correctly), a simple search on Amazon for a male quick connect fitting and a trip to Lowes to find the adapters to connect everything and Wala, an easy way to connect about any Coleman grill to your units propane supply.Click image for larger version
Name:	Coleman grill quick connect fitting.jpg
ID:	120531 Then I got creative and made a T fitting to be able to connect 2 gas appliances at the same time, in my case a small fire ring (so we can cook marshmallows without the wife complaining about that darn wood smoke getting into her motorhome).Click image for larger version
Name:	Quick Connect T fitting.jpg
2015 Georgetown 364TS, '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
'16 - 51 days camping so far, 19 more min planned; '15 - 56 days
2011 Flagstaff V-Lite 30WFKS '14 - 24, '13 - 33, '12 - 36, '11 - 29, '10 - 23
SternHappens is offline   Reply With Quote
Old 09-19-2016, 01:23 PM   #10
RVnut's Avatar
well we bought this set up at camping world and I believe it all came as a package.. No adapters and it has worked great all summer
ID:	120669   Click image for larger version
ID:	120670   Click image for larger version
ID:	120671   Click image for larger version
ID:	120672   Click image for larger version
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
georgetown, propane
