Old 02-02-2015, 06:34 PM   #1
MarkAnne's Avatar
Propane Connections
I returned home from my first major trip to the smell of propane outside the MH. I opened the compartment door to the hissing sound of escaping propane. I turned off the valve and all was well. I found the the connection to the valve was "hand loose". In other words it was so loose I could turn it with my fingers! Check your connections and don't travel with the gas on.
2010 Georgetown 337 DS
MarkAnne is offline   Reply With Quote
Old 02-02-2015, 07:36 PM   #2
abjb's Avatar
Same thing happened to us, another example of FR quality control .
Our dealer said they check for leaks 3 times, I believe him.
After I turned the valve on and nothing came out he looked at me a little funny.
Till I asked him if they tested it at 60MPH and reached down and shook the connection a little .
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-06-2015, 11:09 AM   #3
WDK
WDK's Avatar
Under most conditions, I don't think it very practical to travel with the propane turned off. While I could run my frig from the inverter tooling down the road, the intention was for it to run off propane. I still feel good enough to roll 8 to 12 hours a day and no frig is going to keep your milk fresh that long or my ice cream from melting. Do check your connections perhaps use a gas sniffer on occasion and always be as safe as you can....if you have a leak it's just bad sitting in the park next to other unsuspecting campers as you are driving down the road.
WDK
WDK is offline   Reply With Quote
Old 02-06-2015, 11:48 AM   #4
I had the same problem with my TT. The hose going into the regulator from the tank was only hand tight. Lost a 1/4 tank of propane before I realizes it was leaking (wind was blowing the propane away so I did not smell it). Tightened it properly and have not had an issue in the last 3 years.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
propane
