Old 12-05-2015, 05:33 PM   #1
Propane Fitting & Hose for BBQ
Anyone know the size of the fitting for the Propane quick connect on a '15 Georgetown 270? The one I have for the home BBQ is a different size.
Thanks!
Treedoc is offline   Reply With Quote
Old 12-06-2015, 10:24 AM   #2
RVnut's Avatar
When we picked up our 364 the 2nd of November we asked about the hose at the dealer.. They had the hoses but said the problem is if your have a BBQ or stove that already has a built in regulator ( which most of them do) then you cannot use it since the motorhome source is already regulated.. We decided to bag it for now and keep using the round green cylinders
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 12-06-2015, 10:45 AM   #3
nomad297's Avatar
All you need to do is remove the exisiting regulator from your propane grill and thread a couple nipples and adapters together to hookup to your RV propane grill line.
Bruce
nomad297 is online now   Reply With Quote
Old 12-06-2015, 11:19 AM   #4
onetonford's Avatar
I have never had to remove second regulator since they only close on pressure rise they usually don't cause any problems.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 12-06-2015, 12:24 PM   #5
Dr Travel
Camco RV 4-Port Propane Tee - Walmart.com
robsshots is offline   Reply With Quote
Old 12-06-2015, 01:36 PM   #6
Happily Retired Member
The tee set up we purchase for our 2013 378ts was designed to screw into the propane line outlet before the regulator so the cross over line supplies non regulated propane to whatever you connect to it. Then the grill uses its own regulator . The kit comes complete with the tee that goes inline between tank out line and regulator, end caps for the tee fitting that goes to the cross over line. and the crossover line. I think the kit was about $75.00 at Camping World. The tee itself has a check valve for the crossover fitting so you can disconnect the crossover when not in use without having to shut off the propane tank supply. All the threaded fittings are correct male/ female threads so no other adapters are required. End caps are also in the kit. Since the crossover line is rubber I never travel with it connected.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 12-06-2015, 01:37 PM   #7
Blog: RVroadtripper.com
hbillsmith's Avatar
I believe this youtube video will answer all your questions. Its for a Weber Q1200 but the principals are the same.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 12-06-2015, 08:56 PM   #8
I had to replace my forest river one on the rig because I could not find one to work. So I took it off and bought a new female and new male for the outdoor grill
2016 Rockwood Sig. Ultra Lite 8312SS Platinum
2016 GMC Sierra 3500
Equal-i-zer 10K WDH
Tadi Brothers 9" Wireless 120 degree Rear Cam
2015 Nights Camped: 4
2016 Nights Camped: 8
hazmat91180 is offline   Reply With Quote
Old 12-06-2015, 09:01 PM   #9
Retired Techie
Thanks!
Type 250. Had a real problem finding one. Finally got one at a boat place
moligney is offline   Reply With Quote
Old 12-07-2015, 07:16 AM   #10
New:
compman69's Avatar
Does anyone know where the grill outlet is on the 328ts? I have looked from end to end?!?!?
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
bbq, propane
