Forest River Forums
Sunline User Photos
Old 10-29-2011, 03:31 PM   #1
Propane Furnace
Greetings All,
We are on our second trip in our new 2012 Georgetown 350. It got chilly this morning so I went to turn on the heater. I started the generator to make a pot of coffee. When I turned the heater on the AC unit came on too and the fan started blowing. I do not have the heat pump on my unit. I turned the generator off and the AC went off and the heater stayed on. There are 2 AC units on 2 thermostats. This is happening on the main unit.
There is a recall on the Dometic thermostats and the dealer replaced them for us last week. These are the new ones that aren't supposed to have the thermal shut down "feature".
So, why is the AC unit coming on when 110v power is available?
Thanks in advance.
John
johnnc is offline   Reply With Quote
Old 10-29-2011, 04:58 PM   #2
sherdep's Avatar
I am just throwing guesses out
they could have mis-wired it
check the thermostat - maybe you had the switch to turn the blower on or the thermostat was turned all the way down below what the tempature was inside
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-29-2011, 05:15 PM   #3
greenliner's Avatar
Just had this problem, I'm going to quote the service tech from his work order - removed cover at A/C and found the problem was the signal wire to furnace was broken at the connector, replaced connector and tested furnace, all working properly. Hope this helps you to narrow down a possible cause.
If you can't wake up with a smile on your face, go to bed with a coat hanger in your mouth!!
2005 Ford F150 5.4
2011 Salem 21FBS
Nights out/away with this TT - 58
greenliner is offline   Reply With Quote
Old 10-29-2011, 05:22 PM   #4
Thanks greenliner, I will check it out.
Old 10-29-2011, 05:58 PM   #5
Send a message via Skype™ to Falcon35
On mine the fan seting on the thermostat has to be set at auto or it will start the AC fan with the heat.
2012 Georgetown 378 2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Falcon35 is offline   Reply With Quote
Old 10-31-2011, 10:43 AM   #6
Thanks Falcon, I will try that next. I checked the wiring on the thermostat yesterday but everything looked correct. I will check the fan setting this afternoon.
The rv is going back to the dealer today anyway so if I don't figure it out I will ask them to look at it.
I will report back.
Old 10-31-2011, 03:35 PM   #7
Falcon is the winner. The issue was the Fan was set to Hi, not Au. I feel stupid for not checking that setting.
thanks again Falcon!!
Old 10-31-2011, 04:27 PM   #8
johnnc:
That's OK
I found that out the hard way myself.
Old 10-31-2011, 05:47 PM   #9
greenliner's Avatar
We're all winners because I didn't realise about the fan setting.
2005 Ford F150 5.4
2011 Salem 21FBS
Old 11-10-2011, 08:29 PM   #10
I have a 2011 Georgetown 300 and I have the same problem with front a/c fan coming on with heater. My thermostat does not have auto setting.
ask4doug is offline   Reply With Quote
Close [X]
