Old 06-04-2015, 08:27 PM   #1
jcw
Propane leak
Just returned from a quick fishing trip in Lake Erie. Camped overnight, and I turned the furnace on as the temps were dropping to 60F. Not sure if it is related, but upon return (4 hour drive), I heard a loud hissing sound coming from the coach. Walked around and opened the propane hatch. Low and behold, propane was leaking from the white plastic box, that does not appear to be easily removed. This box is just to the right of the shut off valve, which is below the fill spigot. Lost about 3/4 of a tank of propane.
Any ideas before I take it in to the dealer? Just want to avoid the coach being tied up for an easy fix.
jcw is offline   Reply With Quote
Old 06-04-2015, 09:40 PM   #2
Iggy's Avatar
That is the propane regulator that was leaking.
The white cover is only held on with plastic wire ties. Anyway mine is that way.
Old 06-04-2015, 10:17 PM   #3
jcw
Why would it do that, aside from being defective?
Old 06-04-2015, 10:30 PM   #4
Iggy's Avatar
The only idea is that it was over filled beyond the temp mark on the gauge which is actually 3/4 full mark. This all depends on where you were when it was filled, temperature and altitude.
It may have just been too much pressure in the tank and expanded and blew out the weakest point. This is just a non-educated guess my friend.
Old 06-04-2015, 10:31 PM   #5
I don't have a Georgetown I have a 2014 Berkshire but my propane regulator also started leaking and cost me an entire tank of propane. And that's back when propane spiked in the Midwest and it was $5 per gallon, yikes! I think this is a well known problem with FR.
Marcusfan
2016 Forest River Georgetown 364TS
marcusfan is offline   Reply With Quote
Old 06-05-2015, 09:07 AM   #6
My regulator blew on the way to Phoenix but just lost a little propane, heard it leaking when setting up for camp. Lucky me there was an onsite propane person who had new regulators and replaced it for me. He showed me the old regulator and the new regulator. What a difference in quality. By the way the old one split in half when removing.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 06-06-2015, 10:31 AM   #7
abjb's Avatar
JCW
Check your connections.
We lost our 1st tank because of a finger tight connection from the factory.
When we did a test at the dealership no leak, then I shook the hose and out came the white cloud.
Dealer was not happy, he said they always do the leak test 2 times and he would mention this type of leak to his techs.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 06-07-2015, 06:57 AM   #8
jcw
As a follow up, I removed the plastic cover and can see clearly where the regulator failed. Seems like a pretty easy replacement. I reached out to Forest River about them sending me replacement part, but after this failure and the fact that many other have has similar issues, I am not sure I want the same low quality part. Can someone post a link to the double regulator alternative replacement part that I can order? See attached picture.
Name:	ImageUploadedByForest River Forums1433678264.176023.jpg
Old 06-08-2015, 03:19 PM   #9
Retired US Army CW4
Tom and Kat's Avatar
Regulators are inexpensive and easily replaced in a few minutes. I'm confused. Why would you want a double regulator?
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
Old 06-08-2015, 03:36 PM   #10
jcw
The only regulators I am familiar with is on a gas grill. Those are a single disc regulator. From the photo I posted, there are 2 discs, in series, hence my phrase "double regulator." Admittedly, I am a newbie, and wanted to get other people's input on the part they used as a replacement rather than the stock FR replacement.
leak, propane
