Old 03-24-2013, 09:44 AM   #1
Propane smell
I have a 2013 Georgetown XL 378 and lately I can smell propane now and then right outside the front door. Does anybody else have this issue?
XL 378 is offline   Reply With Quote
Old 03-24-2013, 10:08 AM   #2
SYE
SYE's Avatar
Sounds like you have a leak!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-24-2013, 10:09 AM   #3
Mountainmanbob's Avatar
might need a sniffer
you might wish to
mix up some soapy solution in a spray bottle
spray on all gas hose and fittings you can get to
watch for bubbles
any smell of gas is worth immediate investigation
if you can't find a leak
professionals have special sniffers so as to locate if needed
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-24-2013, 10:15 AM   #4
TURBS's Avatar
Although I don't have your make or model I had a propane leak last year.
I could smell it around the front of my 5er.
I mixed up soap and water in a sprayer bottle and started squirting fittings and found it almost instantly and found that a brass fitting was over tightened at the factory.
Dealer replaced that fitting and several others under warranty.
No leaks since.
Turbs
Old 03-25-2013, 12:28 PM   #5
We had the same thing happen turn out to a bad pop off that would open ever now and again
trell is offline   Reply With Quote
Old 03-25-2013, 03:26 PM   #6
copsuno's Avatar
I had a leak at the tank, where the gas line brass screws into the valve, it vibrated loose twice before l put some plumbers tape on it, now not an issue.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 03-25-2013, 05:56 PM   #7
I woulfd not hesitate, would be back at the dealers and talking safety issues with the manager. This could be a fatal leak, let your warrenty handle the problem. They need to troubleshoot and repair it. Remember, you have one door and a propane leak just outside that esdcape route. Let them be responsible for all problems.
jmacintyre is offline   Reply With Quote
Old 03-25-2013, 06:53 PM   #8
I suspect you have a leak near the refrigerator. Suggest you turn off propane at the tank have dealer fix under warranty.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
ohiobill is offline   Reply With Quote
