Old 05-27-2014, 12:22 AM   #11
Originally Posted by Ford Idaho View Post
I do not see the model number of your unit so.
Is the stove in a slide?
It's a Magic Chef on the slide.
georgetown50 is offline   Reply With Quote
Old 05-27-2014, 12:27 AM   #12
Originally Posted by kenandterry View Post
You posted that "suddenly the stove decided not to work". I'm assuming that means everything worked fine in the hours/days just before.
Aside from the hints submitted by others, are you sure the LP gas detector is still functioning okay. On my unit there is a green flashing light to indicate it is working. Without it working, it will stop the flow of gas to everything as is designed.
Have you verified the fridge switches over and runs on gas okay.....or have you verified the furnace works okay?
It worked one day, next day didn't work. No apparent reason. I just checked the LP Gas Detector and it is off and they green blinking light is off. Could this be the culprit????
Old 05-27-2014, 01:11 AM   #13
Ford Idaho's Avatar
One problem I have see before is a rubber gas line will get kinked from the in and out motion of the slide.
Run the slide out and check the hose.
Old 05-27-2014, 04:02 AM   #14
fonzie's Avatar
Yes, normally LP detector has to be on as it usually operates a propane solenoid at the main tank. LP detector off = solenoid de-energized and no propane.
Fonzie
propane
