Old 05-25-2014, 10:55 PM   #1
Propane won't work on the stove
Suddenly, yesterday the stove decided not to work. When I turn the knob for propane to get to the stove, I do not even hear the usually propane noise you might here when turning the knob. Trying to light obviously doesn't work. I'm not out of propane. I checked the inside indicator and it reads 2/3. The outside indicator on the propane tank reads 1/2. Not really sure what else to do at this point. Any suggestions?
georgetown50 is offline   Reply With Quote
Old 05-26-2014, 12:05 AM   #2
Will any of the top burners or the oven light?
Have you used it this year?
Check for spider webs at the air mix points they might be clogged.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-26-2014, 12:13 AM   #3
Another thought did you try a match to light the burner in case the sticker is bad.
Old 05-26-2014, 04:40 AM   #4
Since you don't hear any gas coming out of the stove, you are probably not getting any. You can try turning the gas off at the tank, then turn it back on very slowly. The propane tanks have surge valves that will shut off the flow of gas if it starts to flow too quickly. If that doesn't work, run another appliance that runs off of gas. If other appliances work, you probably have a bad regulator on the stove. If no appliances work, you have a bad regulator on the tank or no gas in the tank. How reliable are your level indicators. Since you are getting two reading between inside and outside, I think they are not too reliable!
Good luck!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 05-26-2014, 07:29 AM   #5
kenandterry's Avatar
You posted that "suddenly the stove decided not to work". I'm assuming that means everything worked fine in the hours/days just before.
Aside from the hints submitted by others, are you sure the LP gas detector is still functioning okay. On my unit there is a green flashing light to indicate it is working. Without it working, it will stop the flow of gas to everything as is designed.
Have you verified the fridge switches over and runs on gas okay.....or have you verified the furnace works okay?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-26-2014, 07:38 AM   #6
Could have a bad regulator.
Old 05-26-2014, 08:16 AM   #7
Ford Idaho's Avatar
I do not see the model number of your unit so.
Is the stove in a slide?
Old 05-26-2014, 08:57 AM   #8
Love My Sunseeker
DXSMac's Avatar
I hate to do the "Well DUH" suggestion, but did you turn your propane tank ON? If so, never mind.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 05-27-2014, 12:15 AM   #9
None of the top burners light. The Microwave/Convection work fine. Yes, I've used it this year. We are full-timers and this problem just started.
Old 05-27-2014, 12:20 AM   #10
JOE GA,
Thanks for your response. I think it might be the regulator you are talking about on the stove. The indicators differ but I doubt both of them would be bad. I would assume the one on the tank outside would be more accurate so we probably have a half tank of propane in there. I am not sure how to turn the gas off at the tank. I'll have to investigate that again in the morning.
propane
