Old 08-26-2016, 08:21 PM   #1
wvphil's Avatar
Proper oil for 378 leveling system
I have three questions on different subjects so Im going to post three times since different subjects. Anyone know correct type of oil for 378 leveling reservoir? Also should it be checked with all slides in and jacks up?
2013 Georgetown 378 XL
wvphil is online now   Reply With Quote
Old 08-26-2016, 10:25 PM   #2
You do check the level with the slides in and the jacks up. It takes a standard ATF, I had to add a pint on a new 377 to read at the full mark. That is the way it came from forest river.
revflyer is offline   Reply With Quote
Old 08-26-2016, 11:31 PM   #3
Witch Doctor's Avatar
Micron 2 ATF is what I was told, just have everthing retracted and be on level ground, fill enough to leave space in tank I think it's 1/4 ....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-27-2016, 07:28 AM   #4
wvphil's Avatar
Thank you. Looks like mine is a little low also
Old 08-28-2016, 08:23 AM   #5
ron377ts's Avatar
Proper fluid level
On the Lippert website , there is info as to which ATF to use .They specify two types,I think mercon 3 & dexcon 4 , don't remember exactly,but that is what you want to use. Fill to 3/4 in. below fill cap on side of tank.
Ron & Joanne
Bella The chihuahua
2014 Georgetown XL 377
2007 Jeep Liberty
ron377ts is offline   Reply With Quote
leveling
