Old 05-23-2017, 11:12 AM   #1
Question regarding Tranny on 2004 359ts
I read a lot about going downhill and using tow haul mode in conjunction with the cruise control to help maintain a safe speed. My MH does not have a tow haul mode but does have a OD lock out (shut off). My question is does this older coach have the ability to use the cruise control to hold the speed to say 55 going downhill if you set it for that or is that only a perk of having the tow haul mode. Would I just have to manually downshift the trans to a lower gear (I have 3 choices, low, second or drive). I retire in a few months and have not had the motorhome on any mountain passes yet and since I am a planner, my mind needs to know! Thanks!
stringplukker is offline   Reply With Quote
Old 05-23-2017, 11:24 AM   #2
llr
my 1994 F53 chassis did not, had to downshift for any engine braking, od off would be the 1st downshift
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 05-23-2017, 02:27 PM   #3
Thank you!
