Old 12-22-2012, 04:31 PM   #11
camper1999's Avatar
I use small tension curtain rods.Works for me.
2011 GMC 2500HD Diesel
Old 01-06-2013, 03:13 PM   #12
I brushed a thin coat of Rhino liner on the compartments.....nothing moves in there. If you do it, be smarter than me and wear breathing protection.
MGOBlue is offline   Reply With Quote
Old 01-08-2013, 09:27 AM   #13
I must be packed tight enough because nothing seems to move but I do have more room.
XL 378 is offline   Reply With Quote
Old 01-08-2013, 10:28 AM   #14
MGOBlue, Where do you get the Rhino liner from and is it expensive? This is a good thread, I've been thinking about it too.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 01-08-2013, 10:49 AM   #15
sherman12, I got a gallon online for about $75-$80. The gallon was enough to do the top pass thru compartments as well as the floors of most of the other compartments. It's also easy 'hose out' clean up. By the way, I also put a coat on the steps. Works great!!
Old 01-09-2013, 08:43 AM   #16
MGOBlue, Thanks! Something I plan to look at when Spring set up comes around.
sherman12
Old 01-09-2013, 01:06 PM   #17
Iggy's Avatar
I have decided to use a set of small straps with rachets.
I bought a set of 4 - 12 ft cargo strapsfrom Home Depot for $13 and now I think I will find some D hooks to mount in the cargo area. I just need them to secure folding chairs that lay horizontal in the cargo area under the MH floor.
I may just drill a hole in the plastic wall and insert the hook ends of the straps.
Any ideas or suggestions?
Old 01-09-2013, 01:42 PM   #18
Iggy, I would mount small hooks on one side, attach some kind of corded rope with a loop end and mount another hook on the opposite opening and use a good grade bungee across cargo to tie down the chairs etc. If I don't go with the Rhino stuff this is probably what I'll do. Sorta same way I put the tire covers on my rig, rope around back side of tire, loop each end and a small bungee across outside of wheel.
Another concern I had are the infamous hydraulic hoses that are exposed in the pass through compartment. I plan on adding additional zip ties, perhaps alot, and may even wrap them in somthing so stowed chairs and such don't bang on them.
sherman12
Old 01-11-2013, 09:48 AM   #19
Anacortesians
Having stuff move around hasn't been an issue for us and the bays aren't crowded. The bays are all carpeted, presumably factory installed and that seems to provide enough friction. The only thing I have restrained is the 10-lb "squatty" propane bottle for my Q220 grill. I got a plastic ring from CW which I bolted to the floor of one bay. The bottle snaps in from above, but ti fairly easy to take out when we use the grill.
Frank and Eileen
No longer RVers or FR owners
Old 01-11-2013, 02:45 PM   #20
Iggy's Avatar
The 2012 year it seems that just didn't want to invest in carpets so all I have is slick plastic. I have purchased some cheap door mats from the 98 cents store and placed them on most of the bottom compartments but it seems they still move around.
Oh well.
