Amazon. TPMS. EK215. I got the T10 with 10 sensors. 6 tires on RV and 4 on the TOAD. Little cheaper than other options. It drove from Florida to North Dakota and no issues. And a huge peace of mind. $377 prime. Much recommended.
Retired USAF
2018 FR3 29DS
Calls Space Coast of Florida home...but Roll Tide
Hi everyone,1st time on here hope someone could help me find my inverter on 2016 georgetown 378xl, thank you in advance
The inverter could be in a couple of places. 1. Check in the space beneath the refrigerator from the outside. there may be a black cover over the space to protect the inverter from the elements. 2. check in the space above the propane tank. again there may be a black cover that can be removed and the inverter may be tucked in the 6-8" space above the tank. hope that helps.
__________________ 2014 Georgetown XL 352QS 2013-2019 Days Camped-502
I am using the EEZTire Pressure Monitoring System, they are a little more expensive, it came with 10 monitoring buds 6 for RV and 4 for the tow car 4 down. The transmission signal is great, I do not need to have any booster/repeater. Use it on my current trip, and it works really well. Easy setup and monitor.
We have a 378. Our inverter is above the propane tank. There is one of those 6" screw in covers. But I had to remove the black plastic shield for "real" access.
The cap is good enough to view the GFI is or is not tripped.
I use innotech tmps. George the rep is in Georgia. They stand by their product and it is under 400 for unit with10 sensors. Works great opportunity my 378xl with a need for a booster
