Old 09-16-2015, 01:00 PM   #1
questions about the 378 xl
I am new here but have a few questions.
I have a terrible noise coming from the passenger side of coach while driving , sounds like a bad shock , anyone have this issue ?
when running the front furnace , cannot get the rear furnace to blow hot air , also when using either furnace the flame on the stove is very low .
The rv is a 2015 Georgetown 378 xl Black Diamond . thanks for your input.
boondocking fool is offline   Reply With Quote
Old 09-17-2015, 10:41 AM   #2
was hoping to get some input , love the coach but would like to get this fixed , anyone have these same problems before , thanks
Old 09-17-2015, 11:08 AM   #3
LittlePM's Avatar
We have the 2014 Georgetown XL378, we haven't had any of the problems that you have.
You might want to get a front end alignment done.
Both of my furnaces work just fine, together or separate and it doesn't effect the stove at all.
I hope someone else can help you, good luck get it all worked out.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 09-17-2015, 11:13 AM   #4
Thanks for the input , I am taking it in for warranty work was wondering if this was a common thing , will post what they find , other than that really do enjoy the coach , I plan on using it in the winter every weekend so hope it can handle low temps without freezing up............................
Old 09-17-2015, 07:54 PM   #5
You may want to check the propane regulator at the propane tank. If it has a leak in it like mine did it will affect the pressure and that may be why your furnace is not working properly. I had to replace mine a couple of weeks ago it sprung a leak, took me a couple of weeks to figure it out though, started with a slow leak. Then on one weekend i lost half a tank of propane, guess the hole got bigger and poof it was gone. Just glad nobody threw a cigarette under the propane tank when it was leaking! There are threads on this topic here.
DuncanM
2014 Georgetown 335DS
Lincoln MKX toad
DuncanM is offline   Reply With Quote
Old 09-17-2015, 08:06 PM   #6
Luckily for you it is still under warranty
As for the noise it could be the bushing on the sway bar, bushing on the shock or even a bushing on the springs though I am not a mechanic. As for the furnace my first guess would be the regulator
For the winter time we use a couple of ceramic heaters to supplement the furnaces because the furnaces use a lot of gas when the temps get low.
Post what you find out is a good idea.
Our coach is a 2013 378 also
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 09-18-2015, 02:56 PM   #7
We had a loud rattle coming from underneath our 378. Turned out to be the front hydraulic ram on the right slide. Was not tight when slide was retracted. After adjustment, rattle disappeared. Sounded like front suspension.
2011 Georgetown 378 towing 2011 Chev HHR 2LT
ohiobill is offline   Reply With Quote
Old 09-18-2015, 09:40 PM   #8
Thank you all for the info I think the noise could be the ram also will check regulator , really like this site as it is very informative and some great people here also
