Old 01-02-2015, 03:05 PM   #1
Ran out of propane
Need ideas. Should get to 28 tonite it's (378xl) I have artic pacs on and a lamp on outside of fridge should I put a lamp in the compartment where the hose connections are ,it is in a very sealed metal building
rwehba is offline   Reply With Quote
Old 01-02-2015, 03:22 PM   #2
A freezer is a Sealed Metal Box,what is the Temp inside that Metal Building? Youroo!!
Old 01-02-2015, 03:36 PM   #3
It's not insulated think I,ll go head and put a lite in compartment
Old 01-02-2015, 03:45 PM   #4
The_Rhino's Avatar
Are you saying that when you have propane the TT furnace runs & exhausts inside the sealed metal building? IMO you are better-off having a couple small electric heaters that you keep on low...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 01-02-2015, 04:52 PM   #5
Not sealed that good and no one is in it just don,t want anything to freeze
Old 01-02-2015, 05:01 PM   #6
Oaklevel's Avatar
Since you have electricity as mentioned for your light electric heaters would help.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 01-02-2015, 05:10 PM   #7
Thanks I just put some heat lamps in certain spots
Old 01-02-2015, 07:22 PM   #8
bigben's Avatar
If you just getting down to 28 degrees - I wouldn't worry much. I believe your 378 and our 351 have mostly PEX plumbing. PEX is way more resistant to burst that standard PVC or copper tubing. The biggest worry (if you've got your Arctic Pack turned on) is you're probably gonna need a hose that is not frozen in the morning. I believe your unit has heat strips - so turn 'em on and take a good chilly sleep.
US Army - Retired and loving it with our Georgetown 351DS and now our Thor Challenger 37TB.
bigben is offline   Reply With Quote
Old 01-02-2015, 08:07 PM   #9
BamaBob's Avatar
Buy yourself a couple of these and put them fore & Aft in your MH and you will be good to go!
Amazon.com - DeLonghi EW7707CB Safeheat 1500W ComforTemp Portable Oil-Filled Radiator - Black - Heaters
The nice thing about this model is DeLonghi has a "Freeze" setting: the heater will turn on automagically when the temp drops below 44º
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-03-2015, 11:38 AM   #10
aerohead34's Avatar
I have been staying in my Cherokee 284 BH for several months while I work away from home. I have a radiator style heater (oil filled) that does a good job of keeping my camper 68-70 degrees inside. My gas heat (thermostat set on 67) comes on about once a night when the temps get in the low 30's. I have the winter package which has the underneath sealed and insulated. I still open the cabinets where the water is located at night. I have my electric heater on a timer. it comes on at 5:30 PM and cuts off at 10AM. I have a light also attached to the timer so I can check at a glance to see if the timer is working. It took a while to find a timer with three prong outlets. Depending on the size of your camper, I think an electric heater would be a good solution. I got mine at Walmart for under $50. Its basically the same heater that HSVBamaBob listed except it doesn't have the thermostat.
2013 Cherokee 284BH
2017 RAM 3500HD Laramie, Mega Cab, 4X4
aerohead34 is offline   Reply With Quote
propane
