Old 03-25-2014, 05:11 AM   #11
cjd10's Avatar
Originally Posted by alparmmer View Post
I can't stand rattles either. I have to admit that our GT is very quiet down the road all things considered. I've battling the tick tick from the front hub caps. I thought it was just the driver's side, but the passenger one does it too.
Al,
My 98 GT320 had the exact same hubcaps that made a noise. I had to put washers under the two lug nuts that actually hold the hubcap on as they were bottoming out on the studs and not holding it tight enough. That worked on my old MH.
Haven't had a chance to try the pads on my screen door as you suggested yet.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 03-25-2014, 07:41 AM   #12
Originally Posted by cjd10 View Post
Al,
I'll have to try that, thanks.
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 03-29-2014, 06:24 PM   #13
intercept's Avatar
On the 378 fireplace I had to run a bead of silicone rubber to stop the left and right verticle sides of the glass to stop the rattle. Put painters tape on the metal and another strip on the glass. Push the glass in some caulk, release the pressure, wipe off the excess and then remove the tape. Let it sit overnight before moving the coach. You may find like us, that a background noise disappeared.
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 03-30-2014, 07:07 AM   #14
cjd10's Avatar
That might just work on the screen door panel as well. I think I even have some black silicone that will match. Thanks. I'll let you know how it works.
Charleston SC
Old 03-30-2014, 09:06 AM   #15
Krazymace's Avatar
The noise that most annoys me is the vibration of the screens against the passenger and driver side widows while underway. Haven't figured our a solution other than to remove the screens.
Krazymace is offline   Reply With Quote
Old 03-30-2014, 03:30 PM   #16
We just got back from FL and during one of the stops I was bored checking things out. I found out that three out of the four screws that fasten the inside door latch plate were about to fall out. The third one was about one turn loose. Funny thing was that when I tightened them all down the door kept coming open while on the road...not fully opened, but enough to cause the steps to extract. Come to find out if I fully tighten the two screws closest to the edge of the door, the locking slide only comes out about half way. When I loosened them a bit, then it will fully lock. I could not figure out why. I ended up putting some Loctite to make sure they don't come loose again.
Old 04-03-2014, 11:54 PM   #17
GABoy's Avatar
Krazymace
I had that same rattle from the screens. Removed screens and stuck on some Velcro over the edges in few spots. Replaced screens and no more rattles!👍
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 04-04-2014, 05:13 AM   #18
Originally Posted by GABoy View Post
Krazymace
Genius! Looks like a trip for Velcro is in order!!
Campingmomx4 is offline   Reply With Quote
door
