Old 06-16-2015, 04:42 PM   #11
BobHanke's Avatar
There is a drop down door in the wardrobe side of the bedroom (bottom rear). Both 120VAC and 12VDC breakers/fuses are there. Another clue to the location of that main panel is to look directly above where the shore line connects in one of the basement compartments....probably rear left in a motor home. Dirty fuse and loose ground might act the same. Cheers!!
BobHanke is offline   Reply With Quote
Old 06-16-2015, 05:10 PM   #12
My 120VAC and 12VDC fuses are top left over the bed. I've checked all those.
I also just checked all the fuses in the battery bay and in the fuse box in there Everything looks clean and tight.
I'm at a complete loss.
5nomads is offline   Reply With Quote
Old 06-16-2015, 08:00 PM   #13
BobHanke's Avatar
To be clear, I pulled and tested each 12VDC fuse and tested for continuity. Noticed the funky one while doing this. Scraped both sides of that fuse before putting back in. Just back from checking. My bed reading lights and closets are protected by fuse #5 which is labeled "15 Amp Bedroom". #3 "15 Amp Rear Ceiling" probably handles both independent ceiling fixtures plus the ones controlled by the wall switch.
Old 06-16-2015, 09:12 PM   #14
RetiredRVer
Originally Posted by DAPYES View Post
not sure where they originate, but we replaced our entire switch,(2), with 12 volt dimmer twist knobs and they work great so they are dimmable.
This is a great idea! Could you tell me where you purchased your 12v dimmers?
I've spent too much time looking on the net already!
Thanks, Joe Koenig
checkmate99 is offline   Reply With Quote
Old 06-17-2015, 05:19 AM   #15
we have that problem as well. repair shop says it is somewhere in the slide with the wires scraping on something there. They were going to drop the underbelly and pursue it further. For now, we are mounting stick up lights til we are ready to pursue that repair further. Good luck!
lhlee14 is offline   Reply With Quote
Old 06-17-2015, 08:11 AM   #16
UG, I was afraid of something like that. I really don't want to pull new wire or dismantle anything.
Maybe some of those battery operated LED lights that you can just stick up there would work for now.
Old 06-17-2015, 04:07 PM   #17
GABoy's Avatar
Isn't it under warranty? Take it in. Don't worry about it anymore.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 06-17-2015, 06:27 PM   #18
We're on the way to Alaska, so we really can't.
bed, king bed, light
