Old 06-15-2015, 03:41 PM   #1
Reading lights over king bed.
Hi:
The reading lights recently stopped working over the king bed in the rear of our Georgetown 364 bunk house. I've replaced every burnt out fuse I can find, which ended up making no difference to anything. Does anyone know where the power originates for those two lights?
I have traced it under the bed, through the floor then it disappears as it runs to the front of the coach.
Any help is appreciated, thanks!
5nomads is offline   Reply With Quote
Old 06-15-2015, 03:43 PM   #2
Could be the bulbs or loose connections in the lights themselves.
Old 06-15-2015, 04:17 PM   #3
I wish it were that simple. I dismantled the fixture to check the voltage on the wire, there is none. It's not getting power to the fixture.
Old 06-15-2015, 04:32 PM   #4
Did you check both fixtures? They are probably connected together. Try tracing them to an overhead light. The wiring is crazy in rv's as you are finding out. The ground wires are notorious for not being grounded.
Old 06-15-2015, 10:45 PM   #5
Excellent question, I'll make sure tomorrow. Neither fixture works. A single pair of wires goes into the wall behind the bed and there are two pairs at the fixture I tested with a crimp connector. Presumably the extra pair goes to the other fixture. No power there, I'll make sure there's nothing wrong at the other fixture too. But this leads me to believe the problem is with a fuse I can't find.
Old 06-16-2015, 12:30 PM   #6
Now power to the other fixture, it's the end of the line so there's no where to trace after that.
I'll have to crawl under the rig again to see if I can find out where it goes. I was hoping someone would know where that line runs and hooks into the power so I could start at the source.
Thanks again.
Old 06-16-2015, 01:06 PM   #7
not sure where they originate, but we replaced our entire switch,(2), with 12 volt dimmer twist knobs and they work great so they are dimmable.
DAPYES is offline   Reply With Quote
Old 06-16-2015, 01:08 PM   #8
That's a good idea, I like it.
Old 06-16-2015, 02:54 PM   #9
BobHanke's Avatar
On first outing this year, the light over slide out dinette stopped working. Nephew did extensive tests at the light and found there was a good ground and voltage which dropped from 12 to 7 when any load was applied. Stared at the other end at home. I removed every 12V fuse and tested. Found one had a bit of scorch spot and plastic head was slightly melted. Cleaned off scorch. After all that, the light has been working fine.
BobHanke is offline   Reply With Quote
Old 06-16-2015, 04:02 PM   #10
Sbryant's Avatar
Bob, where was that scorched fuse located - which fuse box. Thanks
Sbryant is offline   Reply With Quote
bed, king bed, light
