Old 09-26-2016, 06:21 PM   #11
Happily Retired Member
The alternator may be over charging. Have seen this several times over the years, causing bulbs to blow. Is a bit strange rear bulbs only.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is online now   Reply With Quote
Old 09-26-2016, 06:28 PM   #12
Iggy's Avatar
Here is some info I found on your 2007 Ford F-53 chassis
ID:	121392   Click image for larger version
File Type: pdf Owners_Manual_Ford-F53-Motorhome-Chassis-2007.pdf (1.43 MB, 9 views)
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 09-26-2016, 07:40 PM   #13
Crookedread
crookedread's Avatar
You got great ideas and seem to have it solved but one suggestion that wasn't made was that brakes are for wimps, and why would I turn if I'm on the right road?? Not a very good suggestion but my point was that the best weapon is to keep smiling. This didn't seem to get you down at all which is a good lesson for all of us!!
Crookedread
2016 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 09-26-2016, 07:44 PM   #14
northstar1960's Avatar
Originally Posted by GeorgeM1956 View Post
I just purchased a 2007 Georgetown. The rear lights worked pulling off the lot according to the seller. By the time I got home the brake lights, emergency flashers and turn signals quit working in the rear only, front still works. All other lignts, parking , running etc. work fine.
Anyone have any ideas? I've been through every fuse box I could find, the one by driver's left foot and the one in the forward compartment infront of the engine...are there more fuses?
I'm at a loss,
Thanks,
George
I'll bet you it's a bad ground for the tails . more often then not they undercoat the frame before putting the ground on and then you get poor contact . pull the ground, scrap down to metal then reattach
northstar1960 is offline   Reply With Quote
Old 09-26-2016, 07:48 PM   #15
Iggy's Avatar
Crookedread
2016 Duramax
2011 Stealth 2312
This reply makes no sense to the electrical problem.
Who are you talking to?
Did you accidently write it in the wrong thread?
USAF Retired - MSgt
Old 09-26-2016, 08:18 PM   #16
rsdata's Avatar
I have seen my share of corroded light sockets on trailers... reminded me of last February in FL, my neighbor camper saw me working on my TV, and inquired if I was a mechanic... I asked his problem and he showed me that his headlights, turn signals and rear taillights were all crazy... not responding correctly to what he turned on or used. He had paid some Camping World to diagnose his older motorhome and they told him it would take a new wiring harness and about $1,000 of labor to correct... they only charged him $300 for diagnosis.
Turns out the rear taillight sockets were corroded, the front side turn signal light sockets were corroded and one of the headlight sockets was badly corroded and one of the wires to the other headlight had a bad crimp... I found the bad crimp by wiggling the wire bundle and a wire fell off of the connector.
After cleaning the sockets with some sandpaper I happened to have and using his wife's nail file to clean the socket for the headlights all of the lights started working again. It took about an hour to clean the sockets and get all the lights checked out and working. He was so greatful... He asked me why and how I knew to look at the light sockets... my response was to look at the simple solutions first and make sure all of the bulbs were working and making good contact... something some repair shops obviously don't know how to do.
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 09-26-2016, 08:54 PM   #17
Crookedread
Iggy
Seriously need to find your sense of humor!
Crookedread
2016 Duramax
2011 Stealth 2312
Old 09-27-2016, 08:10 AM   #18
Rear lights not working...
Thank You Iggy! For some reason it took me a while to find page 2 of this thread....much much appreciation for the manual and other documents. rsdata, yes the entire rear light assembly on both sides were corroded and are being replaced with LED assemblies. I think I'm going to check the front light assemblies considering the state of the rear...
Thanks again all, I hope this thread will be helpful to others that may run in to the same problem. It's the beauty of forums - stored, accessible and free knowledge available to share and help our RV communities.
Sincerely,
George Moureau
GeorgeM1956 is offline   Reply With Quote
