Old 03-27-2016, 10:03 AM   #1
Rear outer tire valve stem location on 2014 Georgetown 335Ds
Can someone advise me as to where the valve stem is located on the outer rear tires
JerseyJerry is offline   Reply With Quote
Old 03-27-2016, 11:26 AM   #2
I Break Everything
mikel68's Avatar
We have 351DS, I can only assume they are the same. Ours had and extender on one and I had to put an extender on the other. Kind of a "J" shaped extender. I have big hands, it wasn't fun. Taking off the wheel cover may help you find it, or you'll have to stick your fingers in those cover holes. Do you have picture?
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 03-27-2016, 07:23 PM   #3
Sounds like someone put the wheel trims on the wrong way. That is, not aligned with the valve stems. You will probably need 135 degree extenders on the outers, CW sells them.
Take off the wheel trims with the T wrench in your document pack, the three nuts are the ones with the "__" on them. They are also the ones that don't ring when you tap them with the wrench.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 03-28-2016, 09:33 AM   #4
What is CW?
Old 03-28-2016, 09:34 AM   #5
Never mind Camping World
Old 03-28-2016, 09:43 AM   #6
I am confused, I can see not being able to see the inside wheel valve, but the outer wheel should be clearly visible
Carmen is offline   Reply With Quote
Old 03-28-2016, 03:04 PM   #7
It's there but is a short straight stem. It is almost impossible to check pressure or add air. Just look real close in the wheel cut outs.
db7512 is offline   Reply With Quote
Old 03-28-2016, 03:09 PM   #8
Maybe your wheel liner not on right, could be half turn out ?.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 03-30-2016, 03:38 PM   #9
BillMFl's Avatar
My outer rear valve stems are pointed into the hole instead of out. Had to buy dual head pressure gauge and dual head hose end to test or fill the outer tires.
BillMFl is offline   Reply With Quote
Old 03-30-2016, 11:06 PM   #10
Krazymace's Avatar
I put extenders on all 6 of my tires.
Krazymace is offline   Reply With Quote
2014, cat, georgetown, location, tire
