Old 07-27-2016, 02:37 PM   #1
Rear TV Removal
I want to hook up a Roku to our Rear TV. I can't figure out how it has been installed. I need to hook up a HDMI Cable but there isn't enough room to reach the connection without removing the TV first. Does anyone know the answer for me?
David L Horton
2016 Georgetown 328
dphorton is offline   Reply With Quote
Old 07-27-2016, 02:38 PM   #2
I have a 2016 Georgetown 328
David L Horton
2016 Georgetown 328
Old 07-27-2016, 02:56 PM   #3
US Army Retired
ArmyW4's Avatar
I also have a 328DS and have installed HDMI cables on both the front and rear TV's. To access the back of the rear TV go into the right side closet and there is an access panel up near the top. Pull that panel and you have access to the back of the plywood the TV is screwed onto. It's a tight fit but you can stand on a stepladder and get enough of your arm on there to plug it in. I also ran the HDMI cable from the back of the TV down the dead space on the left side of the closet wall and mounted a connector next to the RCA connector wall plate.
ArmyW4 is offline   Reply With Quote
Old 07-27-2016, 02:57 PM   #4
Thanks for the answer. I thought I looked but will look again.
David L Horton
2016 Georgetown 328
Old 07-27-2016, 03:01 PM   #5
US Army Retired
ArmyW4's Avatar
It was a pain getting to the back of the TV through that little hole (my arm looked like a big cat got hold of it) but once it was done I was happy I did it.
Old 07-27-2016, 04:50 PM   #6
My arm also. Since I am on Plavix every time I do something I Bleed. Got it done so that is what counts. The people who work assembling the Motor home need a lesson on how to put in Screws.
David L Horton
2016 Georgetown 328
