Old 12-08-2015, 11:21 AM   #1
ron377ts's Avatar
Rear window in georgetown
Does anyone use the emergency window in the rear bedroom of the Georgetown ,for ventalition, or is this window not recomended for regular use. If you do ise it, what do you do for screen.
ron377ts is offline   Reply With Quote
Old 12-08-2015, 04:18 PM   #2
chrisbailey13's Avatar
The window is not recommended for ventilation. It could fall out of the frame if left unlocked while driving. (at least that is what I have been told)
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 12-10-2015, 12:32 AM   #3
something about drawing the exaugst back into the coach if motor is running....
poorbuthappy is offline   Reply With Quote
Old 12-10-2015, 05:47 AM   #4
ron377ts's Avatar
I GUESS I should have been more specific. I was only wanting to use it when parked. My wife had it open the last time out, with a shoe holding it open. When I saw it I immediately closed it,thinking it was supposed to fall out when opened. I thought it was like the Windows on a bus,when opened they fall out. I as just thinking if you can open them,without theme falling out,it would be nice to have open some times for ventilation. It's the only real window in the bedroom. Just would need a screen to keep out the bugs.
Old 12-10-2015, 10:39 AM   #5
RVnut's Avatar
Maybe this will help: Why You Should Know How The Emergency Exit Windows Work
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 12-10-2015, 11:22 AM   #6
psgrandpa1's Avatar
Use the small windows at the head of the bedpergect
psgrandpa1 is offline   Reply With Quote
Old 12-10-2015, 12:25 PM   #7
The emergency escape window, I leave be. We do use the micro size windows on each side of the headboard that do have screens. We don't open any rear windows while underway, as the hi pressure lo pressure tends to draw road dirt into the coach.
Dc8mdtmech is offline   Reply With Quote
Old 12-10-2015, 01:20 PM   #8
BobHanke's Avatar
Thanks to RVnut for giving us the link to the Emergency Window video. Testing at least once seems like a good idea, BUT with great care as I would not automatically trust that all windows are hinged at the top.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 12-10-2015, 01:23 PM   #9
RVnut's Avatar
Very true I would go on a ladder outside and look for an upper hinge before I tested or make sure some one is ready to catch the window
364 Georgetown 2016
in Montana
Old 12-10-2015, 07:32 PM   #10
I think it's a great idea and have thought about doing this with ours.
Why not take advantage of it if the window is properly hinged and won't fall out and it save you a step in a real emergency. LOL!
I seem to recall someone posted a while back that they used a wooden dowel as a holder.
Often thought about making a screen that attached via Velcro.
Check out this link http://www.jeff-z.com/rv/amods/amods.html
About halfway down the page. Pretty nice, simple and clean mod using two 45 degree pvc elbows.
livingouradventure is offline   Reply With Quote
georgetown
