Old 09-18-2012, 08:50 PM   #31
VinceU's Avatar
Originally Posted by J_KHawthorne
I and several others have changed fans and eliminated the problem. Look for the cooling fan under the coil behind the top vent opening. If it's a whining Sunon cheapo fan, you have found the problem!
Old Sunon fan in top pic was replaced by 2 new Gelid thermo controlled fans in the bottom pic. Silence is golden! This was done back in the spring and has worked great! The 2 new fans move more air and draw less current than the noisy original.
Amazing any of these fans work at all, they must recirc the same air over and over without any baffles or duct.
Whats the access to the fans, upper door? Mine and others it's pull the 200# box. (4 door 1350)
Old 09-18-2012, 08:54 PM   #32
VinceU's Avatar
Originally Posted by f1100turbo
Mine
Turbo noted when you did the mod, working well? I think a touch better than removing frig and allows future main!
Old 09-18-2012, 09:06 PM   #33
TURBS's Avatar
Working very well .
I maintained 32 degrees labor day weekend temp was humid and in the 90's
Old 09-19-2012, 09:39 AM   #34
J_KHawthorne's Avatar
I'm not sure I follow you!
With the 8 cu.ft. Dometic, the fans are actually in a duct, formed by the space between the back of the fridge and the trailer outer wall! The fans do not simply recirculate the same air over and over! There are 2 large vent openings (each one over 1 sq. ft) in the side of the trailer; one at the top and a lower one near the bottom... The air flow is "in" the bottom and "out" the top! There is no need to pull out the fridge, as there is lots of access with the vent cover removed!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 09-19-2012, 10:45 AM   #35
TURBS's Avatar
And we all know heat rises anyway !
Mine has a vent in the bottom then a duct work that goes to the roof.
My fans are mounted within the duct work so as previous poster said it draws in cool air in the bottom and blows hot air out the roof vent.
Turbs
Old 09-19-2012, 02:23 PM   #36
Turbs
You, sir, are indeed a diplomat! Tip 'o the hat to you!
Jim & Kathy
Old 09-19-2012, 10:00 PM   #37
VinceU's Avatar
You sir are not. When you corrected me as to open the top access and change the fans, it prompted me to check your source. Not sure if this is your first RV but I've had motorhomes for 15 years. I've never had two side vents on any of them. Two vents normally fitted in slideouts as in the 29' Crusader. I'd venture to guess maybe 10% or less of RV's have two access covers for fridge. Thats why I asked you, it sounded too easy.
With the 12.5 cu. ft. boxes the fans are mounted on the back, below the finned tubed "condenser". Remove the roof cover one cannot reach down past the sharp finned tubes, you must pull the fridge to access them.
Research this Forum for fans in refridges and you'll see lots of examples of installations of free flowing fans at top of fridges and blowing from the bottom, all without ductwork.
Lastly the fans in this design are in a "Plenum" between the box and outside wall, not a "duct". They do recirculate because they aren't in a duct and the condenser offers resistance to flow and creates backpressure. Of course hot air rises, thats why Dometic and Norcold added fans, they were around for 50 years without fans.
Before you drop the hammer, do some homework. Thanks for your input.
Old 09-20-2012, 10:31 AM   #38
Sorry if I offended you, Vince. I meant no offense.
Jim & Kathy
Old 12-06-2012, 08:16 PM   #39
I had my fans replace in my Dometic rm 1350 refrigator under warranty.The new ones are very quite.I call Dometic and they told me to take to dealer,who agree the fans was very noisy.
manvel is offline   Reply With Quote
Old 11-10-2015, 11:42 AM   #40
Anyone know the easiest way to remove the out side refrigerator door , without breaking the 2 black clips which hold the door in it's frame??
2012 Signature series Ultra Lite 8281WS 5ER.
Thanks in advance
Kidhoule
kidhoule is offline   Reply With Quote
