Old 08-16-2012, 08:23 AM   #1
Refrigerator
I have a 2012 378 georgetown, with Dometic RM1350 refrigator.It is very noisy compare to the frig in my old motor home,it cools good.Does this model run noisy.
manvel is offline   Reply With Quote
Old 08-16-2012, 10:05 AM   #2
Probably the fans in the back. Doin' what they are supposed to do. When running I can hear them as soon as I step out the door and when it's very quite inside I can hear them then, but much more subdued.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 08-16-2012, 01:30 PM   #3
I have the same refrig in our 378. I notice the fan too, but only when it is pretty hot out. It seems to only kick in when the unit is working hard
ohiobill is offline   Reply With Quote
Old 08-17-2012, 09:23 PM   #4
Send a message via Skype™ to Falcon35
They replaced our fridge because the freezer door did not seal and could not be adjusted.
That one and the new on are both very noisy.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 08-19-2012, 07:59 AM   #5
Our 360 had the noisy fans so I went to a computer supply house and bought 2 fans for ten bucks each and replaced them. They are easily accessible from the tot vent outside. That was a year ago and everything now is quiet . Fridge works great.
polkatronron is offline   Reply With Quote
Old 08-19-2012, 05:36 PM   #6
I assume the fans are 12 volt?
Old 08-19-2012, 07:23 PM   #7
Yes they were
Old 08-23-2012, 04:40 PM   #8
I have a 360 also and would love to change those fans. What is the "tot vent"? Is it the one on the side or the top?
DRPNGOUT is offline   Reply With Quote
Old 08-23-2012, 05:30 PM   #9
TURBS's Avatar
Side
Old 08-23-2012, 06:27 PM   #10
Sorry. That was a spelling error. It is the top vent. You will have to cut the plugs from the fans and solder them to the new ones. It is all 12 v so connections are easy.
