Old 08-01-2014, 09:09 PM   #1
Refrigerator Works on 110 But Not LP
My 2014 Georgetown Dometic fridge works great on 110 but stops working when on LP. The flame is burning but no cooling. My service mechanic has never seen this problem but will try to clean propane vent etc. Any ideas?
NSX1992 is offline   Reply With Quote
Old 08-02-2014, 09:30 AM   #2
when my 378 is idle for a period of time, I need to light a burner on my stove to get the gas up into the lines. try that , it will probably cure your problem.
johnnypal is offline   Reply With Quote
Old 08-02-2014, 09:49 AM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
X2!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-02-2014, 11:03 AM   #4
Tim & Lisa Trempert
How do you know the flame was burning? It would be very strange if electric worked yet the burning flame would not as they both work by heating up the high pressure side.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-02-2014, 12:30 PM   #5
The mechanic took the shield off so you can see the flame is burning normally so the problem is not getting propane to the fridge. I have tried switching between 110 and propane with the same result. I watched the flame every hour but still no cooling. The fridge should work no matter where the heat is coming from.
Old 08-02-2014, 04:37 PM   #6
I had this problem in another motor home. Camping World replaced my coach batteries, converter and the electronic board in the refrigerator. There could be enough voltage to keep the burner lit so it doesn't sound like your batteries are bad.
nicholsonv is offline   Reply With Quote
Old 08-02-2014, 05:15 PM   #7
Problem solved. The mechanic removed the orifice that the propane is shot through before the air gap and found a small dirt particle in the center hole. The tiny blockage was enough to reduce the gas flow to
prevent enough heat to operate properly. It cost me $60 instead of $1,500.
refrigerator
