Old 05-22-2016, 03:13 PM   #1
removing the tv
We have a 2016 Georgetown LX. Does anyone know how to get the TV out so you can put HDMI cable in the back of the TV?
Atsvan is offline   Reply With Quote
Old 05-22-2016, 08:42 PM   #2
The tv is in the bedroom. Anyone?
Old 05-22-2016, 09:02 PM   #3
ME
sparks1032's Avatar
How about a picture? Help us help you.
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 05-22-2016, 09:24 PM   #4
camaraderie's Avatar
Atsvan...I have a different model than you but MY bedroom TV is mounted directly to the closets fixture. The only way I've found to get at it is through the side of the closet to the right of where it is mounted....it is a major pain and a 2 person job to "un mount" the 4 bolts that hold it in place while holding the TV in place to prevent it falling. Dunno if there is another way but I've looked and can't find a way. Good luck...I'll be watching to see if someone else knows the secret!
Welcome aboard and good luck with your G'town. Fill in the bottom of your signature to include where you're from and what model you have to make it easier for folks to respond to your questions! You can get to that through the USER CP tab up top!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 05-26-2016, 06:36 AM   #5
I too will be watching for a reply I'm thinking about looking into a mount that will allow the tv to hinge open like a door
Similar to what FR has done on Berkshire living area tvs Also note if the bedroom tv is a Seiki make, you may have problems with receiving cable stations by certain providers. This is due to the tuner in the Seiki tv - while all 3 Furrion tvs have not had a problem in my 360.
360 Georgetown XL 2015
twoclaws is offline   Reply With Quote
Old 06-23-2016, 01:00 PM   #6
The only way to pull the TV out is to remove it. Forest River uses four (4), one on each corner, brackets to hold TV to the wall. You have to remove the screws going through the bracket and into the wall. Had the same problem when I installed my satttilite dish.
JerseyJerry is offline   Reply With Quote
Old 06-24-2016, 12:19 AM   #7
We looked into a mount for the bedroom tv, but ended up building the following instead.
351DS bedroom TV mod
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 06-25-2016, 09:25 AM   #8
WhoDoMan
The tv has a access panel in the closet. If you remove the panel you can get to the HDMI port. Tough to see but if you use the selfie camera mode on a iPhone u can see it. Good luck.
whoDoMan is offline   Reply With Quote
