Forest River Forums
Sunline User Photos
Old 11-07-2011, 09:19 AM   #1
lorlena43's Avatar
Removing Water filter
I am in the process of winterizing my 2012 Georgetown 350DS. The water filter lives behind a panal where the access is a round hole that only one arm fits through. I can not seem to get it loosened so I can remove it. Does anyone have any ideas
lorlena43 is offline   Reply With Quote
Old 11-07-2011, 10:00 AM   #2
too fast turbo sled
f1100turbo's Avatar
Cut the hole bigger?
Pictures?
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 11-07-2011, 11:03 AM   #3
Did you release the pressure from the water line?
Everett & Joan after 57 years together.
2004 1/2 ton Chevy & 2011 Rockwood 1809S
Emptypockets is offline   Reply With Quote
Old 11-07-2011, 11:25 AM   #4
Hoo Dad's Avatar
Are you sure there is not another way to access the filter? I'm glad mine had more than one way.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is online now   Reply With Quote
Old 11-07-2011, 12:22 PM   #5
bend302's Avatar
Can you get an oil filter wrench in there?
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2010...5 , 2011...78,
Nights camped in 2012...57
bend302 is offline   Reply With Quote
Old 11-07-2011, 12:23 PM   #6
lorlena43's Avatar
This is the door the dealer showed me on my walk around. I do not find any more openings. The opening has a threaded cover that you remove. I was told then you were able to reach in and remove the filter. I can reach it without problem, but can not get it to turn. Yes the pressure is released. I can not imagine cutting another hole as you could not cover it to keep the area clean. I will go take a picture shortly
Old 11-07-2011, 12:53 PM   #7
jmduc's Avatar
You may be able to remove the whole panel to get at it . The panel is usually held in by a few screws.
jmduc is offline   Reply With Quote
Old 11-07-2011, 01:41 PM   #8
Hoo Dad's Avatar
You may want to contact your dealer as you should have gotten a wrench that slips on the filter housing to unscrew.
Old 11-07-2011, 01:58 PM   #9
copsuno's Avatar
I concur that you should be able to remove the partition for access. If your filter is same as mine, 2011 360, it would be too difficult to remove thru an access hole. The filter is designed to be removed and reattached by plastic wrench, which slides over the bottom of housing up to just above middle portion. PS my housing and filter are located at your city water connection, have you checked that location, as my water pump is located behind a partition with 5in cut outs.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 42yrs, and 2001 Saturn toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 11-07-2011, 02:17 PM   #10
too fast turbo sled
f1100turbo's Avatar
true ! with the plastic wrench your dealer should have provided it would be easier to remove and install the filter . one handed may be difficult .
Ron and Amy Benhart
Close [X]
