Old 03-01-2016, 05:51 PM   #11
If you haven't drained the tank yet. Get the cap that has the hose fitting on it then drill hole in stuck gate throw the cap on and you can connect a hose and let the tank drain with very little mess .Then you can replace gate valve.
Joe-Barb is offline   Reply With Quote
Old 03-01-2016, 06:55 PM   #12
We had a worse problem with our black tank. The whole handle mechanism broke and black tank was full😨 what i did was took a hack saw to the area where the metal sleeve was and cut a small area out so i could grab the sleeve with a pair of needlenose pliershe part that opens and closes
kholmes is online now   Reply With Quote
Old 03-01-2016, 06:59 PM   #13
I was able to hook the hose up and then open the valve to let it drain. I then had to purchase a new gate valve and put it on. Best thing is it all worked out and i didn't have to clean myself up. Thank God for that!!
Old 03-05-2016, 08:26 AM   #14
Originally Posted by camaraderie View Post
Id try to thread a small plastic tube down the drain pipe attached to a small pump....get as much water out as possible by bucket.Then when you unbolt the valve... There will be much less mess. Time to break out the rubber suit!
Disconnect at "P" trap and get one of those pumps that attach to an elec drill and pump it out...
Jim in Halifax is offline   Reply With Quote
