Old 03-01-2016, 09:36 AM   #1
Replace waste valve stuck closed
The waste valve on our gray tank is stuck closed. Didn't realize it until the tank was full and water backed up in the sink. How do you install a new valve with a full tank without having a mess?? HELP
We have a 2012 class A Georgetown
robbi is offline   Reply With Quote
Old 03-01-2016, 09:46 AM   #2
bubbles's Avatar
If water has backed up into a sink you probably already have a mess because the shower is the lowest drain and backup should have appeared there first. If you have a second half bath then may not be this issue. If you can't get the drain valve open then yeah, it might be a water mess ( if no way to suck tank dry) to change the valve but lucky it is the gray tank side.
Old 03-01-2016, 10:13 AM   #3
Thanks, it is the half bath tank. Thought I'd throw it out. Figured there was no way to avoid a mess.
Old 03-01-2016, 10:14 AM   #4
Thanks Bubbles....figured as much.
Old 03-01-2016, 10:40 AM   #5
bubbles's Avatar
If you haven't done it before the valve is easy to change. 4 screws and nuts. Getting at those screws and nuts sometimes is the real issue. The valve is readily available on line and at camper supply locations. Typically there isn't any issues with opening the valve, just closing it sometimes fails. Try pulling real hard on the valve handle. The gate valve may just be wedged between the gaskets that may have dried out some. You'll get it, good luck.
Old 03-01-2016, 12:44 PM   #6
Rvdixie's Avatar
I know it's not funny but I would pay to see the replacement procedure if it was the black tank. Just kidding.
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
Rvdixie is offline   Reply With Quote
Old 03-01-2016, 01:09 PM   #7
camaraderie's Avatar
Id try to thread a small plastic tube down the drain pipe attached to a small pump....get as much water out as possible by bucket.Then when you unbolt the valve... There will be much less mess. Time to break out the rubber suit!
camaraderie is offline   Reply With Quote
Old 03-01-2016, 01:26 PM   #8
Retired Army MSG!
lazyjj's Avatar
My black tank valve was hard to open on my 2016 Chaparral. I just pulled very hard and it finally released. I have cable type valves which I am not fond of but just had the valve replaced under warranty.
lazyjj is offline   Reply With Quote
Old 03-01-2016, 01:53 PM   #9
Can we get a little more info?
When you pull the handle does the handle pull out and leave the "gate" still closed? That is pretty easy to check with a stiff wire up the drain.
If the handle IS pulling the gate open then you may have the dreaded plastic disk from the hole saw that was used when the tank was installed. The disk washes over the opening thus blocking it. We did and it was the factory that went in to remove said disk.
Good luck and let us know.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 03-01-2016, 02:22 PM   #10
In my vengeance touring edition in the 1/2 bath black and grey is same tank If this is your kitchen sink their should be a galley drain.
Happy Dave is offline   Reply With Quote
Old 03-01-2016, 06:51 PM   #11
If you haven't drained the tank yet. Get the cap that has the hose fitting on it then drill hole in stuck gate throw the cap on and you can connect a hose and let the tank drain with very little mess .Then you can replace gate valve.
Joe-Barb is offline   Reply With Quote
Old 03-01-2016, 07:55 PM   #12
kholmes's Avatar
We had a worse problem with our black tank. The whole handle mechanism broke and black tank was full😨 what i did was took a hack saw to the area where the metal sleeve was and cut a small area out so i could grab the sleeve with a pair of needlenose pliershe part that opens and closes
Kim & Randy Holmes
2016 F350 Turbo Diesel FX4
2014 Palomino Sabre 33 CKTS
(2012: 10); (2013: 17); (2014: 33); (2015: 43);
(2016: 37); (2017: 69); (2018: 90); (2019: 109); (2020: 110)
kholmes is offline   Reply With Quote
Old 03-01-2016, 07:59 PM   #13
kholmes's Avatar
I was able to hook the hose up and then open the valve to let it drain. I then had to purchase a new gate valve and put it on. Best thing is it all worked out and i didn't have to clean myself up. Thank God for that!!
Kim & Randy Holmes
Old 03-05-2016, 09:26 AM   #14
Disconnect at "P" trap and get one of those pumps that attach to an elec drill and pump it out...
Jim in Halifax is offline   Reply With Quote
