Old 06-22-2016, 09:44 PM   #1
Replaced steps but they are working opposite as should
As the title states. I just swapped out my LCI steps on my Georgetown. Got the new ones mounted, plugged them in.
Now when I close the door the steps open, when I open the door they retract.
Anyone have any ideas? Thanks.
Looking for a new rig!!!
2013 Georgetown 329DS - SOLD
2017 Jeep GC Trailhawk TOAD
Klamaths Premium "Porter" JH RIP
Raney's Blazin' "Baxter"
All white Siberian Husky "Turbo"
goin2drt is offline   Reply With Quote
Old 06-22-2016, 09:46 PM   #2
Did you change the doors magnetic switch. One was normally open the other normally closed.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 06-22-2016, 09:49 PM   #3
I did not change out anything other than removed old steps and replaced with new steps. Unplugged old, plugged in new ones.
Old 06-22-2016, 09:51 PM   #4
B and B's Avatar
Motor wiring is backwards.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-22-2016, 09:53 PM   #5
When Lippert swapped out our steps to Kwickee steps they also changed the magnetic switch. They said if they didn't the steps would not function properly.
FROG Member
Old 06-22-2016, 09:58 PM   #6
No other parts came with the steps for one. I looked at the wire colors of the old and the new steps in and out of the harness and they appeared to match but I would agree it seems wiring is reversed. I sent them a note, I guess I will see what they say.
Old 06-23-2016, 06:58 AM   #7
bubbles's Avatar
No wiring is reversed. The door mag switch action is reversed for the kwikee steps from what the LCI switch action is. You need to swap out the LCI door switch with one that is normally open. The LCI switch is a normally closed switch. One other thing, the step power switch needs to be on to keep the steps out when camping (LCI steps required the power switch to be off to keep the steps out when camping). The kit you got should have included a new door magnetic switch.
Old 06-23-2016, 07:19 AM   #8
SeaDog's Avatar
I ran into the same problem with my Class A and had to order a different magnetic door switch to solve the problem
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-23-2016, 12:30 PM   #9
Yeah, the magnetic door switch needs to be changed. You should have gotten the new switch with your new steps. It's a very easy job, just follow the directions that should accompany the new switch.
I did this last year on my 2011 337DS and am very happy with the new steps.
Marvlab is offline   Reply With Quote
Old 06-23-2016, 12:51 PM   #10
Yes, to every thing bubbles posted. Just had my steps replaced, & had to wait another week to get the magnet that should have been sent with the steps.
2013 Georgetown XL 378TS
bobbie2 is offline   Reply With Quote
