Old 08-28-2014, 09:15 PM   #1
Replacing blistered hoses??
Anyone here replace the blister orange hydraulic hoses themselves?? If so how did you relieve the pressure and purge system...any help would be appreciated...
Thanks in advance
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 08-29-2014, 08:18 AM   #2
Had ours replaced under warranty.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 08-29-2014, 06:15 PM   #3
VinceU's Avatar
Thanks in advance
Once closed up and tank refilled with all rams in, operate affected circuit and repeated in strokes/out strokes the circuit will exhaust all air into the sump tank and out. To relieve pressure, remove cables from pump and carefully open the affected circuit, only outflow will be drainage. You must take power from pump.
VinceU is online now   Reply With Quote
Old 08-29-2014, 08:00 PM   #4
So VincU.. To relieve pressure..Disconnect power to leveling unit... And when you say open circuit..are you referring to slowly cracking a line open and letting the pressure relieve itself?? If so how much pressure are we talking about??
Thanks again
Old 08-29-2014, 10:50 PM   #5
jergeod's Avatar
A little over 2100 lbs, be careful.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 08-30-2014, 10:46 AM   #6
VinceU's Avatar
Yes the pump could start otherwise if still connected. Break fitting on defective hose with drip pan.
Old 08-31-2014, 11:07 AM   #7
leomosley's Avatar
Check my post under the thread "Lippert Jacks, Orange Hoses". I just replaced my hoses, and it was pretty simple. Relieving pressure wasn't an issue, and the system self bleeds.
Cheers
Leo Mosley
2011 Georgetown 300S
leomosley is offline   Reply With Quote
Old 08-31-2014, 07:03 PM   #8
Thanks guys.. Waiting on the hoses... Now... Going to tackle the front ones first... Will keep you guys updated on my progress...
Thanks again..
