Old 02-13-2019, 03:49 PM   #1
Replacing Cam Lock on fuel door
Recently had abt 40 gallons of gas siphoned out of our Georgetown 360 XL. Need to replace the cam lock with a NON universal keyed cam lock.
1) any idea on dimensions/size need in replacement
twoclaws is offline   Reply With Quote
Old 02-13-2019, 03:58 PM   #2
Double flat 3/4 hole 3/8 long or 5/8 long with bent tail pc.
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 02-16-2019, 01:46 PM   #3
Thank you Donlock. Tried both sizes. 5/8th a bit too long and door loose/sloppy Then 3/8thnot long enough to have latch reach.
Tried 5/8thagain and I had to use the extra trim ring that was taken from another package and used with the 5/8th AND it’s a perfect fit.
Thanks for your insight and assistance.
twoclaws.
Old 02-16-2019, 01:52 PM   #4
twoclaws.
Did you flip the bent tail pc over?
Don
Old 02-16-2019, 02:01 PM   #5
Nope. Didn’t t think about that.
Actually the new lock came with both a straight and bent. Off my memory the bent was a tad shorter in total length than the straight. I will have to check. The new lock doesn’t t see as robust as the Universal key 751 lock.
I will continue to explore and see if I can find one as robust as the original 751 but not keyed universal.
Old 02-16-2019, 02:06 PM   #6
bob213's Avatar
I have used these. No key.
https://express.google.com/u/0/produ...hoCcooQAvD_BwE
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 02-16-2019, 02:39 PM   #7
Go to your local locksmith get a LSDA cam lock ,ask for keyed different.
Don
Old 02-16-2019, 03:43 PM   #8
bubbles's Avatar
If it's a standard fuel door for GT's you do realize the door can be ripped off without special tools using one hand, right?
Old 02-16-2019, 04:02 PM   #9
Locks keep honest people out. Yep the door could be pried off as could any door.
The theft took place in my storage area where there are numberous rv s There are cameras but not in my area and I made the owner and mgr. aware of the theft
Old 02-16-2019, 05:40 PM   #10
bubbles's Avatar
Don't need locks for honest people and doesn't make any difference to dishonest people if they really want what you have.
Old 02-16-2019, 06:00 PM   #11
Well it will keep his door shut
Don
Old 02-17-2019, 11:11 AM   #12
bubbles's Avatar
My point is and I think it is valid, is that if something unusual was securing the fuel door then a new door and possibly surrounding trim could be the next purchase and repair that is required. Just fuel or fuel and damage?
door, fuel, lock
