Old 12-16-2010, 05:14 PM   #1
Replacing the DVD player
The Executive DVD player has died in our motorhome. I pulled it out and it has a lot of wires going into it. I made a note of the color and what they connections are that they go to.
I have another DVD player but it doesn't have the same type of connection for these wires. It would be a real pain to try and make it work. I think I'd have to go out and try to find a stereo connection to hook the wires up to so it would hook up correctly to the DVD player (Sony DAV-300).
Any suggestions?
georgetown50 is offline   Reply With Quote
Old 12-16-2010, 05:43 PM   #2
Herk7769's Avatar
Seriously, I have no idea what " a bunch of wires" means.
Is it a Component output from the DVD player? Five wires?
Does the one you want to use have 3 wires? One?
Fiber Optic?
There are adapters (some expensive) for just about any system match up. Just need to know where to point ya.
The manual for the DVD player you want to use is http://www.docs.sony.com/release/DAVS300_OM.pdf
It shows an S Video output (DVD only) and composite 3 wires output. It is a Stereo Surround Sound unit and hooks directly up to speakers. Does you camper have a Concertone unit in it now? If so, I doubt this will work without taking out just about everything.
HAM CALLSIGN - KC3FFW
Old 12-16-2010, 07:02 PM   #3
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
If you want sound out of the surround speakers, you'll have to get a surround sound unit not just a regular dvd player to replace it..
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 12-16-2010, 08:04 PM   #4
Herk7769's Avatar
The Sony unit is a surround sound amp as well as a DVD player. It functions much like the Conertone units in most campers.
Old 12-17-2010, 05:16 PM   #5
jsutherl's Avatar
You want to look for the key words. "Home Theater In a Box" or "All in one home theater system" It's essentualy a DVD (or bluray) player and an amplifier in one box.
Here they are at New Egg:
Newegg.com - Home Theater System, Home Theater Package, Home Theater Surround Sound, Home Theater in a Box, Digital Theater System
Best Buy carries them too.
Unfortunately I don't think it's possible to buy them without the speakers so you'll probably end up installing the dvd player/amp box in your motorhome and throwing the speakers away.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 12-17-2010, 05:21 PM   #6
The Old Man
Willis's Avatar
Don't throw them away!
Sell them on eBay...
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 12-17-2010, 05:30 PM   #7
Herk7769's Avatar
Whoa. I think I must have read his post wrong.
"The Executive DVD player has died in our motorhome. I pulled it out and it has a lot of wires going into it. I made a note of the color and what they connections are that they go to. I have another DVD player but it doesn't have the same type of connection for these wires. It would be a real pain to try and make it work. I think I'd have to go out and try to find a stereo connection to hook the wires up to so it would hook up correctly to the DVD player (Sony DAV-300)."
I thought the Executive DVD player was the failure and he wanted to use the DVD player in his Sony DAV-300 as the replacement for the Executive DVD player. Not knowing how the Executive DVD player connected to his Concertone AMP was the question I was trying to answer.
Old 12-17-2010, 06:25 PM   #8
fivecodys's Avatar
Here is what I did:
Concertone Replacement Complete
While you probably will not need to go to the extreme that I did, this might help you identify the wires and retro fit them to a new unit.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 12-18-2010, 01:15 PM   #9
I have 12 wires that went to the speaker connections on the back of the old DVD player. My Sony doesn't quite fit so I'll probably have to find another home theatre DVD. Does anyone have experience with matching up a bare wire connection to a connection on the back of a DVD or stereo that would require a plastic connection? Would I have to crimp the wire into the plastic connection? Basic question but I've just never done it before.
Don't you just love RV maintenance. No room just like a submarine.
Old 12-18-2010, 01:44 PM   #10
KyDan's Avatar
It's fairly simple to figure out which wire is what back there.
I can't give specific but when I replaced mine I just took each
speaker wire and momentarily touched it to a AA battery.
The speaker it goes to will pop or scratch loud enough to locate it.
Put on some masking tape that labels it and move on.
First thing you know, you've got them all tagged.
After that you are connecting the old wires to your new
unit. I just spliced mine together with blue wire nuts from
the electrical isle if my favorite Home Depot.
(Man I should have my own personal parking space there!!)
georgetown
