Old 11-18-2013, 09:39 AM   #1
Iggy's Avatar
Replacing Toshiba 40" LCD with thin LED?
I have the 40" Toshiba LCD model 40FT2U
I'm considering replacing it with a LED type TV which is much thinner.
Has anyone done this in your motorhome and wonder if it will be damaged if I use the existing mount.
See pictures of present mount. May have to mount on wall instead with swivel mount.
Do you think the thinness will shake and get easily damaged?
I'm considering buying a Samsung LED TV model LN40B750
Name:	Mod Picture 018.jpg
ID:	42757   Click image for larger version
Name:	Mod Picture 025.jpg
ID:	42758   Click image for larger version
Name:	Mod Picture 019.jpg
Old 11-18-2013, 11:43 AM   #2
Pete
gartonhl's Avatar
2010 378TS.
We replaced with Visio 42". Factory mounting bracket would not work. I had to re-invent a bracket and mount to ceiling for "driving down the road" stability.
It also allowed us to have additional "open" storage behind the TV. Bracket works great!
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 11-18-2013, 12:18 PM   #3
Pete
gartonhl's Avatar
pics of TV bracket
ID:	42777   Click image for larger version
ID:	42778   Click image for larger version
ID:	42779   Click image for larger version
Pete and Patty
Old 11-18-2013, 09:34 PM   #4
kz08h5's Avatar
Iggy, I wouldn't,think,LED TVs are,any less structurally sound,than LCD TVs. To give you some peace of mind check out some of the newer motorhomes to see any are using LED TVs.
In looking at your pics, I'm not sure,what you have for a mount there. The bolt pattern to attach the mount should be the same,as they are standard. If your existing mount doesn't work try shopping at MonPrice.com. They have a huge selection and the prices are,very good, Make sure you know the weight of the mount. Some of them are still made for the older, flat screens that were,quit,heavy. It weighted more than the Tv
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 11-19-2013, 09:50 AM   #5
kenandterry's Avatar
Iggy........
We have the exact same bracket on our 2010 GT 330TS holding our 32" Toshiba Flat Screen. That particular TV was not the "bestest" or "fanciest" but for the price, it probably fit the need for FR. The bracket is not pretty and I'm not sure who made the actual bracket, but it IS rock solid at holding the TV.
When the time comes to upgrade I'm sure we'll be looking at a different mounting unit. In both our cases (looking at your photos) the bracket mounts to a horizontal tabletop surface as opposed to a wall or ceiling. If it weren't for the fact that the TV is subjected to more movement in an RV than if it were in a home, there wouldn't be a mount at all.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-19-2013, 12:48 PM   #6
raoulwv's Avatar
Iggy,
My '09 378 has a similar bracket and came with a 32" Olevia (worst TV ever). I changed to a 40" Sony. The bolt pattern did not match, so I attached a 3/4" piece of plywood to the bracket and then bolted the TV to the wood.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 11-19-2013, 06:51 PM   #7
Iggy let. S know what and how you did it. We have a 2013 Georgetown 378 XL. Our 40" Toshiba bit the dust and we are replacing it with a 43" to 46" vizio. I like the vizio brand because I already have 2 at home and like them. The issue I have is my tv cabinet is one piece and not a table top like I the pictures. It is enclosed. Somewhat hard to remove and no room or space under or over the TV When I get my unit back from the shop next week I will post my pics. Any help is always appreciated.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 11-19-2013, 06:54 PM   #8
Iggy's Avatar
Here is what my TV area looks like in my 2012 378TS
Old 11-19-2013, 07:05 PM   #9
Wished mine looked like that. My TV is enclose so I am limited on the size. Fortunately the new Vizios LEDs have a very narrow bezel which enables a larger screen. I might be able to fit a 46" one in it. Will keep you posted.
I just love these types of projects
2008 Honda CR-V
Old 11-19-2013, 07:14 PM   #10
Iggy's Avatar
Has anyone mounted a TV on the wall using a universal swing type mount?
Like this one on Amazon?
http://www.amazon.com/Mount-Pros-Pro.../dp/B00A4PVL0E
or
One like this?
http://www.rakuten.com/prod/mount-it...218030120.html
led
